[petsc-dev] backport setup.py to release-3.1
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Sep 16 21:30:13 CDT 2010
  Seems ok.
   Barry
On Sep 16, 2010, at 6:20 PM, Lisandro Dalcin wrote:
> On 16 September 2010 20:09, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> How could I know? If any of my codes works in Apple, I would say it is
>>> just for accident :-). Anyway, I expect to workaround any issue.
>>  How shall I test it? Remember I need line by line instructions :-)
> Give me some time to push my new setup.py and manage the merge in
> -dev, and I'll let you know how to test 3.1.
> For petsc-dev, you can try this:
> cd $PETSC_DIR
> python setup.py sdist
> pip-python install --install-option=--home=$HOME dist/petsc-3.2.dev0.tar.gz
> Next, go $HOME/lib/python/petsc and inspect the stuff in include and
> lib. Perhaps you could setenv PETSC_DIR=$HOME/lib/python/petsc and
> unset PETSC_ARCH, and try to run 'make test' in the full source tree.
> And remember that Fortran stuff is disabled.
> PS: mpi4py now contains info about mpicxx and mpif90. Perhaps I should
> I use them, in the near future we could have f2py wrappers to Fortran
> routines involving PETSc objects... Python is so slow for number
> crunching...
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
