[petsc-dev] backport setup.py to release-3.1
    Lisandro Dalcin
    dalcinl at gmail.com
    Thu Sep 16 18:20:53 CDT 2010
On 16 September 2010 20:09, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> How could I know? If any of my codes works in Apple, I would say it is
>> just for accident :-). Anyway, I expect to workaround any issue.
>  How shall I test it? Remember I need line by line instructions :-)
Give me some time to push my new setup.py and manage the merge in
-dev, and I'll let you know how to test 3.1.
For petsc-dev, you can try this:
cd $PETSC_DIR
python setup.py sdist
pip-python install --install-option=--home=$HOME dist/petsc-3.2.dev0.tar.gz
Next, go $HOME/lib/python/petsc and inspect the stuff in include and
lib. Perhaps you could setenv PETSC_DIR=$HOME/lib/python/petsc and
unset PETSC_ARCH, and try to run 'make test' in the full source tree.
And remember that Fortran stuff is disabled.
PS: mpi4py now contains info about mpicxx and mpif90. Perhaps I should
I use them, in the near future we could have f2py wrappers to Fortran
routines involving PETSc objects... Python is so slow for number
crunching...
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
