[petsc-dev] backport setup.py to release-3.1
    Lisandro Dalcin
    dalcinl at gmail.com
    Thu Sep 16 18:06:56 CDT 2010
On 16 September 2010 19:53, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 16, 2010, at 5:18 PM, Lisandro Dalcin wrote:
>> I've managed to backport setup.py to release-3.1. It does not require
>> any change to BuildSystem or install.py, as I'm simply using
>> os.system() to spawn configure, make and install. Matt agreed that we
>> could add setup.py to release-3.1 (as it would not break anything),
>> and then get the beast working right now. As a plus, this could also
>> be done with SLEPc and slepc4py.
>   Seems fine with me. So long as the setup.py in petsc-dev DOES NOT use os.system().
Of course, this os.system() usage is just temporary hack to get it
working in release-3.1 without changing other parts.
>   BTW: does this work properly on the Apple with the crazy ARCH stuff?
How could I know? If any of my codes works in Apple, I would say it is
just for accident :-). Anyway, I expect to workaround any issue.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
