[petsc-dev] backport setup.py to release-3.1
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Sep 16 17:53:21 CDT 2010
On Sep 16, 2010, at 5:18 PM, Lisandro Dalcin wrote:
> I've managed to backport setup.py to release-3.1. It does not require
> any change to BuildSystem or install.py, as I'm simply using
> os.system() to spawn configure, make and install. Matt agreed that we
> could add setup.py to release-3.1 (as it would not break anything),
> and then get the beast working right now. As a plus, this could also
> be done with SLEPc and slepc4py.
   Seems fine with me. So long as the setup.py in petsc-dev DOES NOT use os.system().
   BTW: does this work properly on the Apple with the crazy ARCH stuff?
   Barry
> Other far less intrusive alternative would be to just upload PETSc
> (and SLEPc) tarballs to PyPI containing my setup.py. Then nothing have
> to be done with current PETSc and SLEPc releases. What do you think?
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
