[petsc-dev] Configure changes
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep 15 08:04:49 CDT 2010
   Nice fresh crash of ./configure configure.log attached
   Barry
On Sep 15, 2010, at 6:24 AM, Matthew Knepley wrote:
> I have reorganized the temp dir structure into what we wanted:
>   framework has a top-level tmpDir (petsc-foo) per run
>   each module has its own dir (petsc-foo/moduleName) below this
>   the tmpDir is destryed by framework.cleanup()
> and the Windows bug should be fixed.
>    Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100915/a510f8db/attachment.obj>
