[petsc-dev] BuildSystem: PCC=mpicc, CXX and FC
Lisandro Dalcin
dalcinl at gmail.com
Tue Sep 14 20:24:16 CDT 2010
On 14 September 2010 21:55, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 14, 2010, at 6:24 PM, Lisandro Dalcin wrote:
>> 1) If mpicc is in $PATH, then petscvariables will get PCC=mpicc.
>> Perhaps it should get the full path instead?
>> 2) I think CXX and FC variables should be renames to PCXX and PFC. The
>> former names can easily conflict with CXX and FC defined in user
>> makefiles for use with non-MPI sources.
> Then we should also get rid of CC
> Essentially you are saying we should remove all "traditional" use of these variables from our makefiles? I agree doing that might be a good idea. But doesn't it contradict your attempt to try hard to conform to standard usage for things?
Sorry, I need a clarification: Could you tell me why PETSc makefiles
uses PCC instead of the "traditional" CC? Is it just because PCC
could be CC or CXX depending on --with-c-language?
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
