[petsc-dev] BuildSystem: PCC=mpicc, CXX and FC
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Sep 14 19:55:30 CDT 2010
On Sep 14, 2010, at 6:24 PM, Lisandro Dalcin wrote:
> 1) If mpicc is in $PATH, then petscvariables will get PCC=mpicc.
> Perhaps it should get the full path instead?
> 2) I think CXX and FC variables should be renames to PCXX and PFC. The
> former names can easily conflict with CXX and FC defined in user
> makefiles for use with non-MPI sources.
   Then we should also get rid of CC
    Essentially you are saying we should remove all "traditional" use of these variables from our makefiles? I agree doing that might be a good idea. But doesn't it contradict your attempt to try hard to conform to standard usage for things?
   Barry
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
