[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported	for type: mpiaij!
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Sep  3 12:59:21 CDT 2010
  Jed,
    Thanks for your help on this.
    So is the current problem (with the MatLoad) essentially solved? and we can close this case.
   Barry
On Sep 3, 2010, at 1:01 PM, Jed Brown wrote:
> On Fri, 3 Sep 2010 12:53:07 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Sep 3, 2010, at 12:52 PM, Jed Brown wrote:
>>> On Fri, 3 Sep 2010 11:57:59 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Jed,
>>>>   Any sorting algorithm that gives good performance is what we need. The particular algorithm class doesn't matter.
>>> The issue is the possibility/probability of hitting a bad-case for
>>> quicksort.  Robust quicksorts usually do something different if they
>>> detect that pivot choice is going poorly (like do a lot of work to
>>> choose a good pivot or switch to heapsort).  Heapsort usually costs
>>> slightly more than quicksort, but I think most users would be willing to
>>> pay that in exchange for guaranteed O(n log n) performance (as far as I
>>> know, sorting is never an especially performance-sensitive kernel in
>>> PETSc, but it's a big deal if 1 second turns into hours occasionally
>>> (e.g. when the mesh is changed)).
>>   Ok, when we add drop tolerance ILU this requires something like a sort and we found the sort was really making the factorization slow.
> Okay, I'll keep that in mind and hopefully get around to putting in a
> robust sort with good constants.
> Jed
