[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
Jed Brown
jed at 59A2.org
Fri Sep 3 12:52:04 CDT 2010
On Fri, 3 Sep 2010 11:57:59 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Jed,
> Any sorting algorithm that gives good performance is what we need. The particular algorithm class doesn't matter.
The issue is the possibility/probability of hitting a bad-case for
quicksort. Robust quicksorts usually do something different if they
detect that pivot choice is going poorly (like do a lot of work to
choose a good pivot or switch to heapsort). Heapsort usually costs
slightly more than quicksort, but I think most users would be willing to
pay that in exchange for guaranteed O(n log n) performance (as far as I
know, sorting is never an especially performance-sensitive kernel in
PETSc, but it's a big deal if 1 second turns into hours occasionally
(e.g. when the mesh is changed)).
> Thanks for looking at this and improving the results dramatically. BTW: if maintaining the PETScStack and that stuff is slowing down the debug version a lot because of the recursion you could take the PetscFunctionBegin()/Return stuff from the private function that recursives.
I did, but for a different reason, see the third bullet:
changeset: 16901:fb7c48e8b485
user: Jed Brown <jed at 59A2.org>
date: Fri Sep 03 18:44:43 2010 +0200
files: src/sys/utils/sorti.c
description:
Speed up PetscSortInt
* Use median of first,middle,last for quicksort pivot selection.
* Use less intrusive partitioning algorithm (many fewer swaps for
almost-sorted array).
* Don't use PetscFunctionBegin/Return for the private recursive
function. It costs some, but more importantly, the depth of recursion
is data-dependent, so it can blow PETSc's stack, thus making
PETSc-provided stack traces useless. The function could never fail
anyway, so this does not lose any error-handling capability.
