[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
Fri Sep 3 11:57:59 CDT 2010
  Jed,
    Any sorting algorithm that gives good performance is what we need. The particular algorithm class doesn't matter.
    Thanks for looking at this and improving the results dramatically. BTW: if maintaining the PETScStack and that stuff is slowing down the debug version a lot because of the recursion you could take the PetscFunctionBegin()/Return stuff from the private function that recursives.
    Barry
On Sep 3, 2010, at 11:55 AM, Jed Brown wrote:
> On Fri, 03 Sep 2010 17:28:55 +0200, Jed Brown <jed at 59A2.org> wrote:
>>  FAST -O1: 2.0 seconds
>>  FAST -O0: 5 seconds
>>  SLOW -O1: 2.3 seconds
>>  SLOW -O0: more than an hour
> The issue here is that my -O0 cases above also had PETSC_USE_DEBUG set,
> which was sorting a problem-sized (2M) element array as a consistency
> check in AOCreateBasic.  In the 102^3 case, it didn't trigger any bad
> behavior from quicksort, but in the 202x102x102 case, it degraded to
> quadratic (and eventually overflowed the stack, despite choosing the
> median-3 pivot).
> I have pushed a new quicksort which avoids this bad behavior for all the
> inputs I tried (and is faster than before on all of these inputs as
> well).  Here is for the 202x102x102 test case with the new
> implementation:
> Debug:
> MatAssemblyBegin       8 1.0 5.3647e-0118.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  2  0  0  0  6   2  0  0  0  8     0
> MatAssemblyEnd         8 1.0 1.3259e+00 1.0 0.00e+00 0.0 2.0e+01 2.9e+04 6.3e+01  8  0 38  0 31   8  0 38  0 42     0
> MatGetSubMatrice       2 1.0 2.0135e+00 1.0 0.00e+00 0.0 2.0e+01 9.6e+06 1.0e+01 12  0 38 51  5  12  0 38 51  7     0
> MatLoad                1 1.0 5.0351e+00 1.0 0.00e+00 0.0 2.1e+01 9.0e+06 4.7e+01 30  0 40 50 23  30  0 40 50 31     0
> MatView                1 1.0 5.0372e+00 1.1 0.00e+00 0.0 1.9e+01 9.9e+06 2.9e+01 28  0 37 50 14  28  0 37 50 19     0
> Optimized:
> MatAssemblyBegin       8 1.0 3.2006e-01 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  2  0  0  0  9   2  0  0  0 15     0
> MatAssemblyEnd         8 1.0 8.3971e-01 1.0 0.00e+00 0.0 2.0e+01 2.9e+04 3.6e+01  9  0 38  0 26   9  0 38  0 44     0
> MatGetSubMatrice       2 1.0 9.9702e-01 1.0 0.00e+00 0.0 2.0e+01 9.6e+06 1.0e+01 10  0 38 51  7  10  0 38 51 12     0
> MatLoad                1 1.0 2.0991e+00 1.0 0.00e+00 0.0 2.1e+01 9.0e+06 2.6e+01 21  0 40 50 19  21  0 40 50 32     0
> MatView                1 1.0 1.7195e+00 1.1 0.00e+00 0.0 1.9e+01 9.9e+06 1.9e+01 17  0 37 50 14  17  0 37 50 23     0
> As a longer term matter, it's still possible to provide an input that
> degrades to O(n^2).  Does PETSc really want to stick with quicksort, or
> would it be worth switching to e.g. heapsort to avoid this?  It's
> usually not a performance-sensitive kernel for our use cases, so I'm not
> wild about going to a more sophisticated sort to eke out a few more
> percent.
> I have not changed any of the sort-with versions.
> Jed
