[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
    Shri
    abhyshr at mcs.anl.gov
    Fri Sep  3 10:15:09 CDT 2010
Leo,
    Jed and I both tried running a MatLoad example (see src/dm/da/examples/tests/ex35.c) with petsc configured in debug mode and had issues running it with your grid size 202 X 102 X 102. This example runs in a reasonable amount of time with the optimized petsc build.
I suggest running your code on a smaller grid (100 X100 X 100 seems to work fine in the debug mode) for now, get it working and then using the optimized petsc build (--debugging=0) for the large grid size.
Shri
----- Jed Brown <jed at 59A2.org> wrote:
> On Thu, 2 Sep 2010 22:09:09 -0600 (GMT-06:00), Shri <abhyshr at mcs.anl.gov> wrote:
> > >   mpiexec -n 2 ./ex35 -X 202 -Y 102 -Z 102 -log_summary
> > > MatAssemblyBegin       8 1.0 3.4185e-01 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  2  0  0  0  9   2  0  0  0 15     0
> > > MatAssemblyEnd         8 1.0 8.8343e-01 1.0 0.00e+00 0.0 2.0e+01 2.9e+04 3.6e+01  9  0 38  0 26   9  0 38  0 44     0
> > > MatGetSubMatrice       2 1.0 1.0293e+00 1.1 0.00e+00 0.0 2.0e+01 9.6e+06 1.0e+01 10  0 38 51  7  10  0 38 51 12     0
> > > MatLoad                1 1.0 2.3205e+00 1.0 0.00e+00 0.0 2.1e+01 9.0e+06 2.6e+01 23  0 40 50 19  23  0 40 50 32     0
> > > MatView                1 1.0 2.1851e+00 1.3 0.00e+00 0.0 1.9e+01 9.9e+06 1.9e+01 19  0 37 50 14  19  0 37 50 23     0
> >   Are these the results with the optimized petsc build?? It takes an
> >   indefinite amount of time to run ex35 with these options with petsc
> >   debug build. Hence Barry suggested to use a profiler and see what's
> >   going on in MatLoad_MPIAIJ.
> That is with an optimized build.  With a debug build, it runs in a
> completely reasonable amount of time for the 100^3 problem, but the
> 202x102x102 size produces bad quicksort behavior (!):
> #3064 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101252) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3065 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101303) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3066 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101405) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3067 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101407) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3068 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101410) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3069 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101416) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3070 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101429) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3071 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101454) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3072 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101505) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3073 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101607) at /home/jed/petsc/src/sys/utils/sorti.c:42
> #3074 0x00007fbef6a9219e in PetscSortInt (n=2101608, i=0x7fbee4299760) at /home/jed/petsc/src/sys/utils/sorti.c:81
> #3075 0x00007fbef7f4786b in AOCreateBasic (comm=0xef0da0, napp=1050804, myapp=0x4b7b2e0, mypetsc=0x47788b0, aoout=0xf04fd0) at /home/jed/petsc/src/dm/ao/impls/basic/aobasic.c:274
> #3076 0x00007fbef7f487e3 in AOCreateBasicIS (isapp=0x1077720, ispetsc=0x1079740, aoout=0xf04fd0) at /home/jed/petsc/src/dm/ao/impls/basic/aobasic.c:367
> #3077 0x00007fbef8009836 in DAGetAO (da=0xf040e0, ao=0x7fffb44efb48) at /home/jed/petsc/src/dm/da/src/daindex.c:158
> #3078 0x00007fbef7f59acf in MatView_MPI_DA (A=0xfd4f10, viewer=0xeefc60) at /home/jed/petsc/src/dm/da/utils/fdda.c:586
> #3079 0x00007fbef729185f in MatView (mat=0xfd4f10, viewer=0xeefc60) at /home/jed/petsc/src/mat/interface/matrix.c:719
> #3080 0x000000000040125c in main (argc=8, argv=0x7fffb44efdf8) at ex35.c:33
> Presumably the difference between debug and optimized is that the bad
> quicksort is less painful when there is no PetscFunctionBegin, but I'm
> surprised that the difference is more than a factor of, say, 50.  Maybe
> the compiler does a significant transformation for the optimized case.
> > > Is this unacceptably slow (do you still want me to profile MatLoad)?
> >   I don't know whether the MatLoad and MatView time can be regarded as fast or slow as i don't have anything to compare it with.I guess for a matrix of size 2M with roughly 20% nonzeros, reading approximately 0.4 M entries from disk in 2 seconds is acceptable,what do you think?
> The file was 180 MiB, reading that in 2 seconds on my laptop sounds
> reasonable to me.
> Jed
