[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
Jed Brown
jed at 59A2.org
Fri Sep 3 05:50:51 CDT 2010
On Thu, 2 Sep 2010 22:09:09 -0600 (GMT-06:00), Shri <abhyshr at mcs.anl.gov> wrote:
> > mpiexec -n 2 ./ex35 -X 202 -Y 102 -Z 102 -log_summary
> > MatAssemblyBegin 8 1.0 3.4185e-01 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 2 0 0 0 9 2 0 0 0 15 0
> > MatAssemblyEnd 8 1.0 8.8343e-01 1.0 0.00e+00 0.0 2.0e+01 2.9e+04 3.6e+01 9 0 38 0 26 9 0 38 0 44 0
> > MatGetSubMatrice 2 1.0 1.0293e+00 1.1 0.00e+00 0.0 2.0e+01 9.6e+06 1.0e+01 10 0 38 51 7 10 0 38 51 12 0
> > MatLoad 1 1.0 2.3205e+00 1.0 0.00e+00 0.0 2.1e+01 9.0e+06 2.6e+01 23 0 40 50 19 23 0 40 50 32 0
> > MatView 1 1.0 2.1851e+00 1.3 0.00e+00 0.0 1.9e+01 9.9e+06 1.9e+01 19 0 37 50 14 19 0 37 50 23 0
> Are these the results with the optimized petsc build?? It takes an
> indefinite amount of time to run ex35 with these options with petsc
> debug build. Hence Barry suggested to use a profiler and see what's
> going on in MatLoad_MPIAIJ.
That is with an optimized build. With a debug build, it runs in a
completely reasonable amount of time for the 100^3 problem, but the
202x102x102 size produces bad quicksort behavior (!):
#3064 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101252) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3065 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101303) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3066 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101405) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3067 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101407) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3068 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101410) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3069 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101416) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3070 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101429) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3071 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101454) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3072 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101505) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3073 0x00007fbef6a91e00 in PetscSortInt_Private (v=0x7fbee4299760, right=2101607) at /home/jed/petsc/src/sys/utils/sorti.c:42
#3074 0x00007fbef6a9219e in PetscSortInt (n=2101608, i=0x7fbee4299760) at /home/jed/petsc/src/sys/utils/sorti.c:81
#3075 0x00007fbef7f4786b in AOCreateBasic (comm=0xef0da0, napp=1050804, myapp=0x4b7b2e0, mypetsc=0x47788b0, aoout=0xf04fd0) at /home/jed/petsc/src/dm/ao/impls/basic/aobasic.c:274
#3076 0x00007fbef7f487e3 in AOCreateBasicIS (isapp=0x1077720, ispetsc=0x1079740, aoout=0xf04fd0) at /home/jed/petsc/src/dm/ao/impls/basic/aobasic.c:367
#3077 0x00007fbef8009836 in DAGetAO (da=0xf040e0, ao=0x7fffb44efb48) at /home/jed/petsc/src/dm/da/src/daindex.c:158
#3078 0x00007fbef7f59acf in MatView_MPI_DA (A=0xfd4f10, viewer=0xeefc60) at /home/jed/petsc/src/dm/da/utils/fdda.c:586
#3079 0x00007fbef729185f in MatView (mat=0xfd4f10, viewer=0xeefc60) at /home/jed/petsc/src/mat/interface/matrix.c:719
#3080 0x000000000040125c in main (argc=8, argv=0x7fffb44efdf8) at ex35.c:33
Presumably the difference between debug and optimized is that the bad
quicksort is less painful when there is no PetscFunctionBegin, but I'm
surprised that the difference is more than a factor of, say, 50. Maybe
the compiler does a significant transformation for the optimized case.
> > Is this unacceptably slow (do you still want me to profile MatLoad)?
> I don't know whether the MatLoad and MatView time can be regarded as fast or slow as i don't have anything to compare it with.I guess for a matrix of size 2M with roughly 20% nonzeros, reading approximately 0.4 M entries from disk in 2 seconds is acceptable,what do you think?
The file was 180 MiB, reading that in 2 seconds on my laptop sounds
reasonable to me.
Jed
