[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
    Shri
    abhyshr at mcs.anl.gov
    Thu Sep  2 18:08:01 CDT 2010
>   You could also use shark on the Mac to profile. Do man shark
 I'll try that. Thanks.
>   gprof is probably unhappy because your code is built with 64 bit arch and gprof only supports 32 bit version or the other way around.
>    Barry
> On Sep 2, 2010, at 5:27 PM, Jed Brown wrote:
> > On Thu, 2 Sep 2010 15:59:15 -0600 (GMT-06:00), Shri <abhyshr at mcs.anl.gov> wrote:
> >> gprof is giving an error when i'm trying to profile the test case i have. Here's the error:
> >> gprof ex35 > log.out gprof: file: ex35 is not of the host architecture
> > If you want to push ex35 and tell me what options to run it with, I'll
> > profile it.  BTW, I'm not a fan of gprof since it's cumbersome and
> > inaccurate.
> > Jed
