[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
    Shri
    abhyshr at mcs.anl.gov
    Thu Sep  2 18:06:29 CDT 2010
Thanks Jed.I've pushed ex35 to the repository (src/dm/da/examples/tests). You can run it with the following options
mpiexec -n 2 ./ex35 -X 100 -Y 100 -Z 100 . Let me know if you can run the example on a grid size of 202 X 102 X 102.
Shri
P.S : You might need to do make in src/dm/da/utils before compiling ex35 if you haven't built the library recently.
----- Jed Brown <jed at 59A2.org> wrote:
> On Thu, 2 Sep 2010 15:59:15 -0600 (GMT-06:00), Shri <abhyshr at mcs.anl.gov> wrote:
> >  gprof is giving an error when i'm trying to profile the test case i have. Here's the error:
> >  gprof ex35 > log.out gprof: file: ex35 is not of the host architecture
> If you want to push ex35 and tell me what options to run it with, I'll
> profile it.  BTW, I'm not a fan of gprof since it's cumbersome and
> inaccurate.
> Jed
