[petsc-dev] Fwd: SACUDA - Cannot compile
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Oct 28 08:06:28 CDT 2010
On Oct 28, 2010, at 4:15 AM, Aron Ahmadia wrote:
> I like Lisandro's approach.  If the developers can provide scripts
> that attempt to identify the usage of Vec and replace them with
> PetscVec, all the better.
   Unfortunately getting the #defines exactly right (including for Fortran) I think is a major bitch as is having a translator script that works perfect; and I hesitate to have something that "works most of the time".
   Barry
> A
> On Thu, Oct 28, 2010 at 11:13 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> On 28 October 2010 06:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Oct 27, 2010, at 10:39 PM, Matthew Knepley wrote:
>>>> On Wed, Oct 27, 2010 at 10:34 PM, Sean Farley <sean at mcs.anl.gov> wrote:
>>>>   Matt had a major hissy fit when I proposed this (again) a couple of years ago.
>>>> What's wrong with a namespace? Isn't this what Matt is proposing the Thrust developers do?
>>>> "I reported it and they know about it. PETSc takes over VecType, and it would be much easier (maybe) for Thrust to just namespace that thing."
>>>> Everybody and their mother uses the names Mat, Vec, etc. why can't PETSc namespace them?
>>>> This is a matter of supporting existing users. Everyone that uses PETSc has Vec and Mat everywhere in
>>>> their code. If we change that, we will have to have an excellent, easy, and fullproof upgrade path or
>>>> everyone will hate us and may not even upgrade.
>>>   Everyone already hates us, so I can live with that. Etags (or ctags with Vim) is the way to go, plus it will force everyone to finally learn tags. People upgrade because there is a reason in the new release to upgrade, if there is no reason to upgrade then why upgrade?
>> What about properly namespace everything, and also provide a
>> compatibility header full of #define's , at least for the next couple
>> of mayor releases?
>> Lisandro Dalcin
>> CIMEC (INTEC/CONICET-UNL)
>> Predio CONICET-Santa Fe
>> Colectora RN 168 Km 472, Paraje El Pozo
>> Tel: +54-342-4511594 (ext 1011)
>> Tel/Fax: +54-342-4511169
