[petsc-dev] Fwd: SACUDA - Cannot compile
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Thu Oct 28 04:15:07 CDT 2010
I like Lisandro's approach. If the developers can provide scripts
that attempt to identify the usage of Vec and replace them with
PetscVec, all the better.
A
On Thu, Oct 28, 2010 at 11:13 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 28 October 2010 06:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Oct 27, 2010, at 10:39 PM, Matthew Knepley wrote:
>>> On Wed, Oct 27, 2010 at 10:34 PM, Sean Farley <sean at mcs.anl.gov> wrote:
>>> Matt had a major hissy fit when I proposed this (again) a couple of years ago.
>>> What's wrong with a namespace? Isn't this what Matt is proposing the Thrust developers do?
>>> "I reported it and they know about it. PETSc takes over VecType, and it would be much easier (maybe) for Thrust to just namespace that thing."
>>> Everybody and their mother uses the names Mat, Vec, etc. why can't PETSc namespace them?
>>> This is a matter of supporting existing users. Everyone that uses PETSc has Vec and Mat everywhere in
>>> their code. If we change that, we will have to have an excellent, easy, and fullproof upgrade path or
>>> everyone will hate us and may not even upgrade.
>> Everyone already hates us, so I can live with that. Etags (or ctags with Vim) is the way to go, plus it will force everyone to finally learn tags. People upgrade because there is a reason in the new release to upgrade, if there is no reason to upgrade then why upgrade?
> What about properly namespace everything, and also provide a
> compatibility header full of #define's , at least for the next couple
> of mayor releases?
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
