[petsc-dev] [petsc-maint #54862] Compiler error with petsc-dev on PC
Satish Balay
petsc-maint at mcs.anl.gov
Mon Oct 25 14:30:24 CDT 2010
Pushed this change now.
Satish
On Sat, 23 Oct 2010, Barry Smith wrote:
> We don't even need it. They can be replaced with PetscTypeCompare((PetscObejct) is,ISBLOCK,&flg);
> Barry
> On Oct 22, 2010, at 3:47 PM, Satish Balay wrote:
> > ISGetBlock() is misleading. And we have ISBlockGetXXX functions.
> > Perhaps we should use ISBlockCheck()/ISStrideCheck().
> > Satish
> > On Fri, 22 Oct 2010, Barry Smith wrote:
> >> Stupid Fortran.
> >> I suggest changing to SGetBlock() and ISGetStride() since Get is common usage. Another alternative is ISIsStride() and ISIsBlock() but we don't commonly use IS so I would avoid introducing it.
> >> Barry
> >> On Oct 21, 2010, at 4:29 AM, Satish Balay wrote:
> >>> Ok - I think the following defs are cris-crossing and causing grief..
> >>> <petscis.h>
> >>> #define ISSTRIDE "stride" /* ISType */
> >>> #define ISBLOCK "block" /* ISType*/
> >>> <src/vec/is/impls/stride/ftn-auto/stridef.c>
> >>> #define isstride_ ISSTRIDE
> >>> void PETSC_STDCALL isstride_(IS is,PetscBool *flag, int *__ierr ){
> >>> <src/vec/is/impls/block/ftn-auto/blockf.c>
> >>> #define isblock_ ISBLOCK
> >>> void PETSC_STDCALL isblock_(IS is,PetscBool *flag, int *__ierr ){
> >>> Perhaps ISBlock(), ISStride() functions should be renamed?
> >>> Satish
> >>> On Thu, 21 Oct 2010, Hammond, Glenn wrote:
> >>>> Still the same errors.
> >>>>> -----Original Message-----
> >>>>> From: Satish Balay [mailto:petsc-maint at mcs.anl.gov]
> >>>>> Sent: Wednesday, October 20, 2010 8:50 PM
> >>>>> To: petsc-maint at mcs.anl.gov; Hammond, Glenn
> >>>>> Subject: RE: [petsc-maint #54862] Compiler error with petsc-dev on PC
> >>>>> if configure is run - its is supporsed to regenerate
> >>>>> fortranstubs.. [and I see configure was run today]
> >>>>> PETSc:
> >>>>> File creation : Generated Fortran stubs
> >>>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/stride/ftn-
> >>>>> auto
> >>>>> stridef.c^M
> >>>>> C:\software\PETSC-~4\src\vec\is\impls\stride\ftn-auto\stridef.c(60) :
> >>>>> error C2059: syntax error : 'string'^M
> >>>>> /usr/bin/ar: stridef.o: No such file or directory
> >>>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/block
> >>>>> block.c^M
> >>>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/block/ftn-
> >>>>> auto
> >>>>> blockf.c^M
> >>>>> C:\software\PETSC-~4\src\vec\is\impls\block\ftn-auto\blockf.c(78) :
> >>>>> /usr/bin/ar: blockf.o: No such file or directory
> >>>>> Found a copy of SOWING in sowing-1.1.15
> >>>>> Looks like you have an old sowing. I guess you need 'rm -rf PETSC_ARCH
> >>>>> externalpackages'
> >>>>> Satish
> >>>>> On Wed, 20 Oct 2010, Hammond, Glenn wrote:
> >>>>>> Of course not. Didn't have to on my Linux box and Jaguar. I will
> >>>>> try again.
> >>>>>> Glenn
> >>>>>> From: knepley at gmail.com [mailto:knepley at gmail.com] On Behalf Of
> >>>>> Matthew Knepley
> >>>>>> Sent: Wednesday, October 20, 2010 8:28 PM
> >>>>>> Subject: Re: [petsc-maint #54862] Compiler error with petsc-dev on PC
> >>>>>> Did you 'make allfortranstubs'?
> >>>>>> Mat
> >>>>>> On Wed, Oct 20, 2010 at 10:25 PM, Hammond, Glenn
> >>>>> <glenn.hammond at pnl.gov<mailto:glenn.hammond at pnl.gov>> wrote:
> >>>>>> PETSc,
> >>>>>> See attached logs.
> >>>>>> Glenn
> >>>>>> What most experimenters take for granted before they begin their
> >>>>> experiments is infinitely more interesting than any results to which
> >>>>> their experiments lead.
> >>>>>> -- Norbert Wiener
