[petsc-dev] [petsc-maint #54862] Compiler error with petsc-dev	on PC
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Oct 23 14:32:06 CDT 2010
  We don't even need it. They can be replaced with PetscTypeCompare((PetscObejct) is,ISBLOCK,&flg);
   Barry
On Oct 22, 2010, at 3:47 PM, Satish Balay wrote:
> ISGetBlock() is misleading. And we have ISBlockGetXXX functions.
> Perhaps we should use ISBlockCheck()/ISStrideCheck().
> Satish
> On Fri, 22 Oct 2010, Barry Smith wrote:
>>  Stupid Fortran.
>>   I suggest changing to SGetBlock() and ISGetStride() since Get is common usage. Another alternative is ISIsStride() and ISIsBlock() but we don't commonly use IS so I would avoid introducing it.
>>    Barry
>> On Oct 21, 2010, at 4:29 AM, Satish Balay wrote:
>>> Ok - I think the following defs are cris-crossing and causing grief..
>>> <petscis.h>
>>> #define ISSTRIDE       "stride" /* ISType */
>>> #define ISBLOCK        "block" /* ISType*/
>>> <src/vec/is/impls/stride/ftn-auto/stridef.c>
>>> #define isstride_ ISSTRIDE
>>> void PETSC_STDCALL   isstride_(IS is,PetscBool  *flag, int *__ierr ){
>>> <src/vec/is/impls/block/ftn-auto/blockf.c>
>>> #define isblock_ ISBLOCK
>>> void PETSC_STDCALL   isblock_(IS is,PetscBool  *flag, int *__ierr ){
>>> Perhaps ISBlock(), ISStride() functions should be renamed?
>>> Satish
>>> On Thu, 21 Oct 2010, Hammond, Glenn wrote:
>>>> Still the same errors.
>>>>> -----Original Message-----
>>>>> From: Satish Balay [mailto:petsc-maint at mcs.anl.gov]
>>>>> Sent: Wednesday, October 20, 2010 8:50 PM
>>>>> To: petsc-maint at mcs.anl.gov; Hammond, Glenn
>>>>> Subject: RE: [petsc-maint #54862] Compiler error with petsc-dev on PC
>>>>> if configure is run - its is supporsed to regenerate
>>>>> fortranstubs.. [and I see configure was run today]
>>>>> PETSc:
>>>>> File creation : Generated Fortran stubs
>>>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/stride/ftn-
>>>>> auto
>>>>> stridef.c^M
>>>>> C:\software\PETSC-~4\src\vec\is\impls\stride\ftn-auto\stridef.c(60) :
>>>>> error C2059: syntax error : 'string'^M
>>>>> /usr/bin/ar: stridef.o: No such file or directory
>>>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/block
>>>>> block.c^M
>>>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/block/ftn-
>>>>> auto
>>>>> blockf.c^M
>>>>> C:\software\PETSC-~4\src\vec\is\impls\block\ftn-auto\blockf.c(78) :
>>>>> /usr/bin/ar: blockf.o: No such file or directory
>>>>>               Found a copy of SOWING in sowing-1.1.15
>>>>> Looks like you have an old sowing. I guess you need 'rm -rf PETSC_ARCH
>>>>> externalpackages'
>>>>> Satish
>>>>> On Wed, 20 Oct 2010, Hammond, Glenn wrote:
>>>>>> Of course not.  Didn't have to on my Linux box and Jaguar.  I will
>>>>> try again.
>>>>>> Glenn
>>>>>> From: knepley at gmail.com [mailto:knepley at gmail.com] On Behalf Of
>>>>> Matthew Knepley
>>>>>> Sent: Wednesday, October 20, 2010 8:28 PM
>>>>>> Subject: Re: [petsc-maint #54862] Compiler error with petsc-dev on PC
>>>>>> Did you 'make allfortranstubs'?
>>>>>> Mat
>>>>>> On Wed, Oct 20, 2010 at 10:25 PM, Hammond, Glenn
>>>>> <glenn.hammond at pnl.gov<mailto:glenn.hammond at pnl.gov>> wrote:
>>>>>> PETSc,
>>>>>> See attached logs.
>>>>>> Glenn
>>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which
>>>>> their experiments lead.
>>>>>> -- Norbert Wiener
