[petsc-dev] [petsc-maint #54862] Compiler error with petsc-dev on PC
Barry Smith
bsmith at mcs.anl.gov
Thu Oct 21 08:12:06 CDT 2010
Stupid Fortran.
I suggest changing to SGetBlock() and ISGetStride() since Get is common usage. Another alternative is ISIsStride() and ISIsBlock() but we don't commonly use IS so I would avoid introducing it.
Barry
On Oct 21, 2010, at 4:29 AM, Satish Balay wrote:
> Ok - I think the following defs are cris-crossing and causing grief..
> <petscis.h>
> #define ISSTRIDE "stride" /* ISType */
> #define ISBLOCK "block" /* ISType*/
> <src/vec/is/impls/stride/ftn-auto/stridef.c>
> #define isstride_ ISSTRIDE
> void PETSC_STDCALL isstride_(IS is,PetscBool *flag, int *__ierr ){
> <src/vec/is/impls/block/ftn-auto/blockf.c>
> #define isblock_ ISBLOCK
> void PETSC_STDCALL isblock_(IS is,PetscBool *flag, int *__ierr ){
> Perhaps ISBlock(), ISStride() functions should be renamed?
> Satish
> On Thu, 21 Oct 2010, Hammond, Glenn wrote:
>> Still the same errors.
>>> -----Original Message-----
>>> From: Satish Balay [mailto:petsc-maint at mcs.anl.gov]
>>> Sent: Wednesday, October 20, 2010 8:50 PM
>>> To: petsc-maint at mcs.anl.gov; Hammond, Glenn
>>> Subject: RE: [petsc-maint #54862] Compiler error with petsc-dev on PC
>>> if configure is run - its is supporsed to regenerate
>>> fortranstubs.. [and I see configure was run today]
>>> PETSc:
>>> File creation : Generated Fortran stubs
>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/stride/ftn-
>>> auto
>>> stridef.c^M
>>> C:\software\PETSC-~4\src\vec\is\impls\stride\ftn-auto\stridef.c(60) :
>>> error C2059: syntax error : 'string'^M
>>> /usr/bin/ar: stridef.o: No such file or directory
>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/block
>>> block.c^M
>>> libfast in: /cygdrive/c/software/petsc-dev/src/vec/is/impls/block/ftn-
>>> auto
>>> blockf.c^M
>>> C:\software\PETSC-~4\src\vec\is\impls\block\ftn-auto\blockf.c(78) :
>>> /usr/bin/ar: blockf.o: No such file or directory
>>> Found a copy of SOWING in sowing-1.1.15
>>> Looks like you have an old sowing. I guess you need 'rm -rf PETSC_ARCH
>>> externalpackages'
>>> Satish
>>> On Wed, 20 Oct 2010, Hammond, Glenn wrote:
>>>> Of course not. Didn't have to on my Linux box and Jaguar. I will
>>> try again.
>>>> Glenn
>>>> From: knepley at gmail.com [mailto:knepley at gmail.com] On Behalf Of
>>> Matthew Knepley
>>>> Sent: Wednesday, October 20, 2010 8:28 PM
>>>> Subject: Re: [petsc-maint #54862] Compiler error with petsc-dev on PC
>>>> Did you 'make allfortranstubs'?
>>>> Mat
>>>> On Wed, Oct 20, 2010 at 10:25 PM, Hammond, Glenn
>>> <glenn.hammond at pnl.gov<mailto:glenn.hammond at pnl.gov>> wrote:
>>>> PETSc,
>>>> See attached logs.
>>>> Glenn
>>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>>> -- Norbert Wiener
