[petsc-dev] Changes in makefiles
    Satish Balay
    balay at mcs.anl.gov
    Sun Oct 17 05:59:16 CDT 2010
changeset:   15795:42e46651d576
user:        balay at mcs.anl.gov
date:        Wed Apr 28 09:54:09 2010 -0500
files:       config/PETSc/Configure.py config/PETSc/packages/mpi4py.py config/PETSc/packages/petsc4py.py config/install.py makefile
description:
- remove 'shared_nomesg_noinstall mpi4py_noinstall petsc4py_noinstall' targets
- move 'shared mpi4py petsc4py' targets out of install.py
- fix dylibs on mac after 'make install' with install_name_tool
[Inorder to better support 'make install DESTDIR=']
However - I don't remember exactly how this helped with DESTDIR...
Satish
On Sat, 16 Oct 2010, Jose E. Roman wrote:
> I am synchronizing slepc-dev with petsc-dev. I am almost finished, but there are some changes in the makefiles that affect us. In particular we used shared_nomesg_noinstall, which is no longer in petscrules.
> Can anyone give me pointers to the changesets where this was modified?
> Thanks.
> Jose
