[petsc-dev] wrong makefile variables?
Lisandro Dalcin dalcinl at gmail.com
Sat Oct 16 13:34:08 CDT 2010
On 16 October 2010 19:17, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Maybe if you told/showed me exactly how you use it we can come up with the optimal set of variables you want?
Take a look here to what I'm currently using:
http://code.google.com/p/petsc4py/source/browse/conf/core/confcore.py#144
I'm not saying that this is optimal, I've always used what PETSc provides.
>   Do you want a flag that says single library or multiple libraries?
Perhaps that could work, but...
>   Do you want a variable with the list of the PETSc libraries?
That's what I was used to get with PETSC_LIB_BASIC. That variable
expanded to "-lpetsc" for single-lib builds, and "-lpetscts
-lpetscsnes ..." for the multi-lib case.
>   Something else?
If you could provide the correct list of PETSc libs in
PETSC_LIB_BASIC, that would be nice, because my code would continue
working with previous 3.0.0 and 3.1 releases.
>   Barry
> On Oct 16, 2010, at 9:44 AM, Lisandro Dalcin wrote:
>> On 16 October 2010 16:23, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Oct 16, 2010, at 3:43 AM, Lisandro Dalcin wrote:
>>>> It seems that after changes to BuildSystem, the makefile variables
>>>> PETSC_LIB_BASIC and PETSC_EXTERNAL_LIB_BASIC are not properly set for
>>>> single-library builds.
>>>   This is a change.  ./configure now generates PETSC_EXTERNAL_LIB_BASIC  and PETSC_LIB_BASIC is never used
>>>  Barry
>> How should I figure if PETSc is using single vs. multiple library
>> builds (remember petsc4py inspect makefile variables to get PETSc
>> stuff)?
>> Any chance you could still generate the correct PETSC_LIB_BASIC, even
>> if core PETSc does not use it?
>>>> A few days ago we had:
>>>> $ grep _BASIC $PETSC_ARCH/conf/petscvariables
>>>> PETSC_LIB_BASIC = -lpetsc
>>>> PETSC_CONTRIB_BASIC = -lpetsc
>>>> PETSC_SNES_LIB_BASIC = -lpetsc
>>>> PETSC_KSP_LIB_BASIC = -lpetsc
>>>> PETSC_MAT_LIB_BASIC = -lpetsc
>>>> PETSC_VEC_LIB_BASIC = -lpetsc
>>>> PETSC_DM_LIB_BASIC = -lpetsc
>>>> PETSC_TS_LIB_BASIC = -lpetsc
>>>> PETSC_SYS_LIB_BASIC = -lpetsc
>>>> but now:
>>>> SL_LINKER_LIBS = ${PETSC_EXTERNAL_LIB_BASIC}
>>>> PETSC_EXTERNAL_LIB_BASIC = -lX11 -llapack -lblas -lm
>>>> -Wl,-rpath,/usr/lib64/mpich2 -L/usr/lib64/mpich2
>>>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.1
>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.4.1 -ldl -lmpich -lopa -lpthread
>>>> -lrt -lgcc_s -lmpichf90 -lgfortran -lm -lm -ldl -lmpich -lopa
>>>> -lpthread -lrt -lgcc_s -ldl
>>>> Could any of you check and fix this?
>>>> Lisandro Dalcin
>>>> CIMEC (INTEC/CONICET-UNL)
>>>> Predio CONICET-Santa Fe
>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>> Tel: +54-342-4511594 (ext 1011)
>>>> Tel/Fax: +54-342-4511169
>> Lisandro Dalcin
Lisandro Dalcin
