[petsc-dev] wrong makefile variables?
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Oct 16 11:17:04 CDT 2010
  Maybe if you told/showed me exactly how you use it we can come up with the optimal set of variables you want?
   Do you want a flag that says single library or multiple libraries?
   Do you want a variable with the list of the PETSc libraries?
   Something else?
   Barry
On Oct 16, 2010, at 9:44 AM, Lisandro Dalcin wrote:
> On 16 October 2010 16:23, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Oct 16, 2010, at 3:43 AM, Lisandro Dalcin wrote:
>>> It seems that after changes to BuildSystem, the makefile variables
>>> PETSC_LIB_BASIC and PETSC_EXTERNAL_LIB_BASIC are not properly set for
>>> single-library builds.
>>   This is a change.  ./configure now generates PETSC_EXTERNAL_LIB_BASIC  and PETSC_LIB_BASIC is never used
>>  Barry
> How should I figure if PETSc is using single vs. multiple library
> builds (remember petsc4py inspect makefile variables to get PETSc
> stuff)?
> Any chance you could still generate the correct PETSC_LIB_BASIC, even
> if core PETSc does not use it?
>>> A few days ago we had:
>>> $ grep _BASIC $PETSC_ARCH/conf/petscvariables
>>> PETSC_LIB_BASIC = -lpetsc
>>> PETSC_CONTRIB_BASIC = -lpetsc
>>> PETSC_SNES_LIB_BASIC = -lpetsc
>>> PETSC_KSP_LIB_BASIC = -lpetsc
>>> PETSC_MAT_LIB_BASIC = -lpetsc
>>> PETSC_VEC_LIB_BASIC = -lpetsc
>>> PETSC_DM_LIB_BASIC = -lpetsc
>>> PETSC_TS_LIB_BASIC = -lpetsc
>>> PETSC_SYS_LIB_BASIC = -lpetsc
>>> but now:
>>> SL_LINKER_LIBS = ${PETSC_EXTERNAL_LIB_BASIC}
>>> PETSC_EXTERNAL_LIB_BASIC = -lX11 -llapack -lblas -lm
>>> -Wl,-rpath,/usr/lib64/mpich2 -L/usr/lib64/mpich2
>>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.1
>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.4.1 -ldl -lmpich -lopa -lpthread
>>> -lrt -lgcc_s -lmpichf90 -lgfortran -lm -lm -ldl -lmpich -lopa
>>> -lpthread -lrt -lgcc_s -ldl
>>> Could any of you check and fix this?
>>> Lisandro Dalcin
>>> CIMEC (INTEC/CONICET-UNL)
>>> Predio CONICET-Santa Fe
>>> Colectora RN 168 Km 472, Paraje El Pozo
>>> Tel: +54-342-4511594 (ext 1011)
>>> Tel/Fax: +54-342-4511169
> Lisandro Dalcin
