[petsc-dev] Why is -I$PETSC_DIR/src/dm/mesh/sieve in CLINKER even when configured without Sieve?
Satish Balay
balay at mcs.anl.gov
Tue Oct 12 17:37:33 CDT 2010
Barry,
I pused some fixes - so you should pull before attempting more fixes
to this code..
Satish
On Tue, 12 Oct 2010, Barry Smith wrote:
> One of the reasons for the repetitive -I and -L stuff in PETSc make lines is that in conf/variables we constructed some variables by adding two variables together that each individually had duplicates eliminated but the result did not have duplicates eliminated.
> I have moved this concatenation of variables back to PETSc/Configure.py so that the duplicates can be eliminated. Specifically this basically means merging the PACKAGES_LIBS and PACKAGES_INCLUDES with the basic libs and and includes before dumping to the conf/variables file
> As always there are likely to be problems crop up with some cases, maybe with shared libraries, with --prefix builds etc. Please report problems to petsc-maint at mcs.anl.gov
> Barry
> More cleanup could be done to eliminate information on individual packages from going into petscvariables etc
> On Oct 12, 2010, at 1:18 PM, Jed Brown wrote:
> >> On Oct 12, 2010 6:48 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> >> On Tue, 12 Oct 2010, Jed Brown wrote:
> >> > This also isn't specific to me, every one of your configure.logs is equally
> >> > relevant. I get Sat...
> >> One more case: where one uses diferent version of gcc vs gfortran [or
> >> g77] - or one of these are installed in a different location.
> >> For eg: on Mac - gfortran paths are totally different than gcc paths.
> >> > So unless someone writes a special case for matching vendors, these
> >> > paths will always exist. ...
> >> We've always maintained that one should configure/rebild after
> >> changing any parameters. So compiler version upgrade is one
> >> such. [yeah lot of changes usually work, but the ones that don't work
> >> -generate petsc-maint requests. Also if this is truly an issue - then
> >> I think the following [with the correct minima LIBS option] is a
> >> workarround for such folks - so the situation isn't too bad..
> >> '--with-clib-autodetect=0 --with-fortranlib-autodetect=0 --with-cxxlib-autodetect=0 LIBS=-lgfortran...
> >> Satish
