[petsc-dev] Why is -I$PETSC_DIR/src/dm/mesh/sieve in CLINKER even when configured without Sieve?
Jed Brown
jed at 59A2.org
Mon Oct 11 17:28:50 CDT 2010
Does it even need to be there at all? Must things like "Map.hh" be in the
public namespace like this? Do we really need -I/usr/lib? How about
-I/usr/local/include (my /usr/local is empty so configure definitely didn't
find anything there, it's not mentioned in my environment either). How
about /usr/include (which is a system directory and need not, indeed should
not, be specified explicitly) and /usr/lib/openmpi which has no C headers in
it and really shouldn't be specified either. Why can't I have
-I$PETSC_DIR/$PETSC_ARCH/include -I$PETSC_DIR/include and *nothing* else
unless I have packages in non-system directories?
This with current -dev, it was cleaner with 3.1 where at least /usr/lib and
/usr/local/include were not shoved in there. I haven't checked when they
crept in.
/usr/bin/mpicc -o ex51.o -c -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g3 -I/home/jed/petsc/src/dm/mesh/sieve
-I/home/jed/petsc/ompi/include -I/home/jed/petsc/include -I/usr/include
-I/usr/lib/openmpi -I/home/jed/petsc/ompi/include -I/usr/lib
-I/usr/local/include -D__INSDIR__=src/ksp/ksp/examples/tutorials/ ex51.c
#!/usr/bin/python
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--with-zoltan-dir=/usr',
'--download-ml',
'--with-blas-lapack-dir=/usr',
'--download-pastix',
'--download-blacs',
'--download-chaco',
'--with-hdf5-dir=/usr',
'--with-sowing',
'--download-superlu_dist',
'--with-cholmod-dir=/usr',
'--download-spooles',
'--download-sundials',
'--download-hypre',
'--with-c2html',
'--with-mpi-dir=/usr',
'--with-umfpack-dir=/usr',
'--with-parmetis-dir=/usr',
'--with-single-library=0',
'--download-scalapack',
'--with-java-dir=/usr',
'--with-lgrind',
'--download-mumps',
'PETSC_ARCH=ompi',
'--download-superlu',
'--download-scotch',
'--download-spai',
'--with-shared-libraries',
configure.petsc_configure(configure_options)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101012/72f59cca/attachment.html>
