[petsc-dev] Location for tutorial codes
    Satish Balay
    balay at mcs.anl.gov
    Fri May 28 13:33:01 CDT 2010
Ok - I've maded the changes [to release and tutorial repos]. Please
update yor URLs for them.
specicfically petsc-31/buildsystem31 are now:
ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.1
ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.1
Satish
On Fri, 7 May 2010, Barry Smith wrote:
> On May 7, 2010, at 3:51 PM, Satish Balay wrote:
> > Barry,
> > there are 2 ways of grouping - one is a prefix, the other is a subdir.
> > The release repos were already grouped with a common prifix - so it
> > didn't need a subdir regrouping. [however this forces url changes for
> > folks with these clones]. Plus the names don't pass your check for
> > duplicate info.
>    I agree.
> > petsc-releases/petsc-release-2.3.1
> > Tutorials were not already grouped [so either a rename or a subdir was
> > appropriate change]
>   Actually the tutorials did have TutorialCode in all their names so they now have duplicate names.
> > If release clones were to be better grouped, perhaps the following
> > organization is better.
> > releases/petsc-2.3.1
> > releases/petsc-3.0.0
> > releases/BuildSystem-2.3.1
> > releases/BuildSystem-3.0.0
>   I prefer using subdirectory names rather than "prefix" in a file name; after all that is what subdirectories are for, otherwise we might as well just use one directory for everything.
>    Feel free to remove the duplicate parts of the file names.
>    Barry
> > [but this requires renaming the parent url aswell as clone names [since some of us
> > usually use the same name for clones as the master repo]
> > Satish
> >>  I have moved the tutorials into a tutorials subdirectory (I did not change the name of the individual directories so they still end in TutorialCode.
> >>  Also made a BuildSystem-releases and petsc-releases and move the old releases into there. People WILL NEED to update there .hg/hgrc for their clones.
> >>  There is a petsc-dev-for-fixes and petsc-dev-new-solvers and petsc-dev-dalcinl can I delete those?
> >>   Barry
> >> On May 7, 2010, at 12:53 PM, Jed Brown wrote:
> >>> On Fri, 7 May 2010 12:36:53 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>>> Seems reasonable to me. Also repositories of BuildSystem and petsc
> >>>> for previous releases could go into two subdirectories
> >>> I don't think I can do that sort of thing since I can't log into the
> >>> machine.  Perhaps one of you can do that, or at least create the new
> >>> directory (so the URL in my slides will be stable for a while after
> >>> Monday/Tuesday).
> >>> Jed
