[petsc-dev] field split/schur complement, incompressible flow
    Lisandro Dalcin
    dalcinl at gmail.com
    Wed May 12 14:34:32 CDT 2010
On 12 May 2010 16:23, Matthew Knepley <knepley at gmail.com> wrote:
> I guess I have no problem with this if:
>   a) Its completely backwards compatible with the options-style
>   b) the YAML part is not going to break the build
> This will likely mean revamping the Options*() API.
1)  Are we going to grab a YAML parser from elsewere?
2) JSON (being a subset of YAML) would not be enough?
> I favor the low-level interface to FieldSplit taking a name and IS.
>    Matt
I agree with Matt.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
