[petsc-dev] PETSC's compilation
David sheehan david.sheehanjr at gmail.com
Wed Mar 24 12:35:35 CDT 2010
Matt already moved it to petsc-maint before.
can you help me to fix the build-up of PETSC and HYPRE? thanks in advance.
David
On Wed, Mar 24, 2010 at 12:09 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> moving this discussion to petsc-maint. Not appropriate for petsc-dev
> satish
> On Wed, 24 Mar 2010, David sheehan wrote:
> > That was an old try.
> > My new try including all output information is the following. Everything
> is
> > OK except for "make test"  has one error.
> > I checked the library of HYPRE. All HYPRE libs have been created, but
> they
> > cannot be installed with PETSC libs.
> > And I manually copy all HYPRE libs into the directory of the
> final-installed
> > PETSC's libs, but "make test" still has
> > the same problem.
> > Please fix it, thanks.
> > David
> > -----------------------------------------------the final installed
> libs-------------------------------------------------------------------------------------------------
> > [ petsc-2.3.3-p15]$ ls /home/David/petsc233-p15/lib/linux-gnu-c-debug/
> > libpetsc.a         libpetscdm.a   libpetscmat.a   libpetscts.a
> > libpetsccontrib.a  libpetscksp.a  libpetscsnes.a  libpetscvec.a
> > ------------------------------------------------PETSC
> libs---------------------------------------------------------------------------------------------------
> > [ petsc-2.3.3-p15]$ ls lib/linux-gnu-c-debug/
> > --------------------------------------------------HYPRE
> externalpackages/hypre-2.0.0/linux-gnu-c-debug/lib/
> > libHYPRE.a                               libHYPRE_MatrixMatrix.a
> > libHYPRE_sstruct_ls.a
> > libHYPRE_DistributedMatrix.a             libHYPRE_multivector.a
> > libHYPRE_sstruct_mv.a
> > libHYPRE_DistributedMatrixPilutSolver.a  libHYPRE_ParaSails.a
> > libHYPRE_struct_ls.a
> > libHYPRE_Euclid.a                        libHYPRE_parcsr_block_mv.a
> > libHYPRE_struct_mv.a
> > libHYPRE_IJ_mv.a                         libHYPRE_parcsr_ls.a
> > libHYPRE_utilities.a
> > libHYPRE_krylov.a                        libHYPRE_parcsr_mv.a
> > libHYPRE_LSI.a                           libHYPRE_seq_mv.a
> ----------------------------------------configure------------------------------------------------------------------------------------------------------
> > [ petsc-2.3.3-p15]$ export PETSC_DIR=$PWD
> > [ petsc-2.3.3-p15]$  ./config/configure.py
> --prefix=/home/David/petsc233-p15
> > --with-cc=gcc --with-cxx=g++ --with-fc=ifort --with-mpi-dir=/opt/openmpi
> > --with-hypre=1 --download-hypre=ifneeded
> >              Configuring PETSc to compile on your system
> > TESTING: configureLibrary from
> > PETSc.packages.hypre(python/PETSc/packages/hypre.py:120)
> > using: --with-MPI-include="/opt/openmpi/include"
> > Compilers:
> >   C Compiler:         gcc  -fPIC -Wall -Wwrite-strings
> -Wno-strict-aliasing
> > -g3
> >   C++ Compiler:       g++  -Wall -Wwrite-strings -Wno-strict-aliasing -g
> > -fPIC
> >   Fortran Compiler:   ifort  -fPIC -g
> > Linkers:
> >   Shared linker:   gcc  -shared  -fPIC -Wall -Wwrite-strings
> > -Wno-strict-aliasing -g3
> >   Dynamic linker:   gcc  -shared  -fPIC -Wall -Wwrite-strings
> > PETSc:
> >   ** Before running "make" your PETSC_ARCH must be specified with:
> >   **  ** setenv PETSC_ARCH linux-gnu-c-debug (csh/tcsh)
> >   **  ** PETSC_ARCH=linux-gnu-c-debug; export PETSC_ARCH (sh/bash)
> >   PETSC_DIR: /home/David/petsc/petsc-2.3.3-p15
> >   ** Now build and test the libraries with "make all test"
> >   Clanguage: C
> >   PETSc shared libraries: disabled
> >   PETSc dynamic libraries: disabled
> >   Scalar type:real
> > MPI:
> >   Includes: ['/opt/openmpi/include']
> >   Library:  ['/opt/openmpi/lib/libmpi.a']
> > X11:
> >   Includes: ['-I/usr/X11R6/include']
> >   Library: ['-L/usr/X11R6/lib -lX11']
> > BLAS/LAPACK: -llapack -lblas
> > hypre:
> >   Includes:
> ['/home/David/petsc/petsc-2.3.3-p15/externalpackages/hypre-2.0.0/linux-gnu-c-debug/include']
> >   Library:
> ['/home/David/petsc/petsc-2.3.3-p15/externalpackages/hypre-2.0.0/linux-gnu-c-debug/lib/libHYPRE.a',
> > '-Wl,-rpath,/usr/lib/gcc/i386-redhat-linux/3.4.6',
> > '-Wl,-rpath,/usr/lib/gcc/i386-redhat-linux/3.4.6/../../..', '-lstdc++']
> > ---------------------------------------------------make
> install---------------------------------------------------------------------------------
> > Installing PETSc at /home/David/petsc233-p15
> > Shared libraries disabled
> > sh/bash: PETSC_DIR=/home/David/petsc233-p15; export PETSC_DIR
> > csh/tcsh: setenv PETSC_DIR /home/David/petsc233-p15
> > Then do make test to verify correct install
> test-------------------------------------------------------------------------------------
> > Running test examples to verify correct installation
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> MPI
> > process
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
> MPI
> > processes
> > Possible error running Graphics examples src/snes/examples/tutorials/ex19
> 1
> > MPI process
> > See
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> > lid velocity = 0.0016, prandtl # = 1, grashof # = 1
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Error in external library!
> > [0]PETSC ERROR: Unable to open display on apmachine:0.0
> > .  Make sure your COMPUTE NODES are authorized to connect
> >     to this X server and either your DISPLAY variable
> >     is set or you use the -display name option
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 15, Tue Sep 23
> 10:02:49
> > CDT 2008 HG revision: 31306062cd1a6f6a2496fccb4878f485c9b91760
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./ex19 on a linux-gnu named apmachine by David Wed Mar 24
> > 11:41:48 2010
> > [0]PETSC ERROR: Libraries linked from
> > [0]PETSC ERROR: Configure run at Wed Mar 24 11:21:40 2010
> > [0]PETSC ERROR: Configure options --prefix=/home/David/petsc233-p15
> > --with-hypre=1 --download-hypre=ifneeded --with-shared=0
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: PetscDrawXGetDisplaySize_Private() line 618 in
> > src/sys/draw/impls/x/xops.c
> > [0]PETSC ERROR: PETSc unable to use X windows
> > proceeding without graphics
> > Number of Newton iterations = 2
> > Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
> MPI
> > process
> > Completed test examples
> > On Wed, Mar 24, 2010 at 9:35 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > On Tue, 23 Mar 2010, David sheehan wrote:
> > > > I try openmpi, there are the following error,
> > > > ./configure --prefix=/home/David/petsc300p11_openmpi --with-cc=gcc
> > > > --with-cxx=g++ --with-fc=ifort --download-openmpi=1
> --download-hypre=1
> > > > TESTING: check from
> > > > config.libraries(config/BuildSystem/config/libraries.py:126)
> > > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > > details):
> > > > Currently --download-openmpi option does not work with --prefix
> install.
> > > > Suggest installing OpenMPI separately, and then configuring PETSc
> with
> > > > --with-mpi-dir option.
> > > > How to fix it? thanks.
> > > configure already gave the answer to your question
> > > satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100324/af69f474/attachment.html>
