[petsc-dev] Any plan to add ParMetis-3.1.1?
Jed Brown jed at 59A2.org
Tue Mar 23 11:30:27 CDT 2010
On Tue, 23 Mar 2010 11:00:04 -0500, Keita Teranishi <keita at cray.com> wrote:
> I'd like to know if you have had any problem with 3.1.1 and if you
> have any plan to introduce this version in the forthcoming PETSc
> release.
I have had a local ParMetis-3.1.1 install for more than a year, with
both petsc-release 3.0.0 and petsc-dev.  If you have installed
ParMetis-3.1.1 yourself, then you should have no problems
--with-parmetis-dir=/path/to/parmetis-3.1.1.
I didn't realize that --download-parmetis installs ParMetis-3.1.0 (plus
some patches), but I expect that there will be no problem updating that
to 3.1.1 (this is independent of PETSc's release, the ParMetis API did
not change).
Jed
