[petsc-dev] PETSC's compilation
David sheehan david.sheehanjr at gmail.com
Mon Mar 22 18:27:23 CDT 2010
I tried it, but it doesn't like mpirun. For example,
if I want to run
mpirun -np 2  pro.ex
then it would be
mpiexec -np 2 pro.ex
, right? thanks.
David
On Mon, Mar 22, 2010 at 5:58 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> As mentioned before - its 'mpiexec'
> Satish
> On Mon, 22 Mar 2010, David sheehan wrote:
> > The "bin" directory has the following files:
> > adiforfix.py           mpich2version     mpiexec.poe
> > parkill                        taucc.py
> > adprocess.py       mpicxx               mpiexec.prun
> > parseargs.py             TOPSGenerator.py
> > chibaoutput          mpiexec             mpiexec.sshsync
> > petsc_libtool              TOPSInstaller.py
> > configVars.py       mpiexec.chiba    mpiexec.uni
> > petscmpiexec             update.py
> > hostnames.chiba  mpiexec.gmalloc mpiexec.valgrind
> > popup                         urlget
> > matlab                  mpiexec.lam      mpif77
> > portabilitycheck.py      urlget.py
> > mpicc                   mpiexec.llrun      mpif90
> > processSummary.py    win32fe
> > which one is "mpirun"? thanks.
> > David
> > On Mon, Mar 22, 2010 at 5:44 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > You should look for mpiexec. It will be in the 'bin' dir for the
> > > prefix used - i.ed /home/david/petscdir/bin/mpiexec
> > > Satish
> > > > I build up petsc successfully as follows
> > > > ./configure --with-cc= --prefix=/home/david/petscdir --with-cc=gcc
> > > > --with-cxx=g++ --with-fc=ifort --download-mpich=1 --download-hypre=1
> > > > make
> > > > make install
> > > > make test
> > > > Also, I can link it with my application. Now I need to run my
> application
> > > > with the petsc, where can I find "mpirun" for the mpich downloaded to
> run
> > > my
> > > > application? thanks.
> > > > David
> > > > On Mon, Mar 22, 2010 at 4:45 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > > You can't use 2 MPIs at same time. i.e use either
> --download-mpich=1
> > > > > or --download-openmpi=1 - but not both.
> > > > > Satish
> > > > > > You mean,
> > > > > > ./configure --with-cc=gcc --with-cxx=g++ --with-fc=ifort
> > > > > --download-mpich=1
> > > > > >  --download-hypre=1 --download-openmpi=1
> > > > > > thanks.
> > > > > > David
> > > > > > On Mon, Mar 22, 2010 at 3:58 PM, Matthew Knepley <
> knepley at gmail.com>
> > > > > wrote:
> > > > > > > On Mon, Mar 22, 2010 at 3:54 PM, David sheehan <
> > > > > david.sheehanjr at gmail.com>wrote:
> > > > > > >> I don't have icc and icpc. I only have ifort and gnu compilers
> > > such
> > > > > > >> g77,gcc
> > > > > > >> and g++. Since my application code works very well with ifort,
> can
> > > I
> > > > > build
> > > > > > >> up PETSC plus Hypre with ifort and gnu compilers? thanks.
> > > > > > > It might be possible (though not guaranteed if ifort conflicts
> with
> > > GNU
> > > > > > > somehow). You
> > > > > > > jsut provide these compilers to the configure, and use
> > > > > --download-openmpi.
> > > > > > >    Matt
> > > > > > >> David
> > > > > > >> On Mon, Mar 22, 2010 at 3:29 PM, Satish Balay <
> > > > > wrote:
> > > > > > >>> If you have installation issues - send the relavent logs [in
> this
> > > > > case
> > > > > > >>> configure.log] to petsc-maint.
> > > > > > >>> Here you appear to try too many things.. But its not clear if
> you
> > > are
> > > > > > >>> installing openmpi/lam yourself - or using default from Red
> Hat
> > > 3.4.
> > > > > > >>> [note - default openmpi will be built with gnu compilers - so
> > > > > > >>> unuseable from ifort].
> > > > > > >>> Thing to do:
> > > > > > >>> - decide on compilers you want to use.
> > > > > > >>> - build PETSc and mpi with these compilers
> > > > > > >>> [for eg: configure CC=icc CXX=icpc FC=ifort
> --download-mpich=1
> > > > > > >>> --download-hypre=1]
> > > > > > >>> Note: alternative f90 compilers seable on linux are gfortran,
> g95
> > > > > > >>> Satish
> > > > > > >>> > Hi,
> > > > > > >>> > I am trying to compile the PETSC with hypre. I have Intel
> > > FORTRAN,
> > > > > > >>> openmpi
> > > > > > >>> > and  lam
> > > > > > >>> > MPI  (gcc version 3.4.6 (Red Hat 3.4.6-3)) available.
> > > > > > >>> > Since my application code is in FORTRAN with dynamic memory
> > > > > allocation
> > > > > > >>> in
> > > > > > >>> > the code,
> > > > > > >>> > so I have to use Intel FORTRAN(ifort) as the compiler to
> link
> > > PETSC
> > > > > > >>> with my
> > > > > > >>> > application
> > > > > > >>> > code. I can build up PETSC(petsc-3.0.0-p11) plus hypre with
> Lam
> > > MPI
> > > > > but
> > > > > > >>> > without ifort
> > > > > > >>> > successfully. However I can not use ifort to link the PETSC
> > > with my
> > > > > > >>> > application success-
> > > > > > >>> > fully. The link always shows erros about "undefined
> reference"
> > > to
> > > > > MPI
> > > > > > >>> parts
> > > > > > >>> > in my application
> > > > > > >>> > code such as 'mpi_send_', 'mpi_recv_', 'mpi_waitany_',
> > > > > > >>> 'mpi_get_count_',
> > > > > > >>> > and etc.
> > > > > > >>> > Can any one help me out? thanks in advance.
> > > > > > >>> > Best Regards,
> > > > > > >>> > David
> > > > > > > What most experimenters take for granted before they begin
> their
> > > > > > > experiments is infinitely more interesting than any results to
> > > which
> > > > > their
> > > > > > > experiments lead.
> > > > > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100322/0a317a76/attachment.html>
