[petsc-dev] PETSC's compilation
David sheehan
david.sheehanjr at gmail.com
Mon Mar 22 16:38:25 CDT 2010
You mean,
./configure --with-cc=gcc --with-cxx=g++ --with-fc=ifort --download-mpich=1
--download-hypre=1 --download-openmpi=1
thanks.
David
On Mon, Mar 22, 2010 at 3:58 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 22, 2010 at 3:54 PM, David sheehan <david.sheehanjr at gmail.com>wrote:
>> I don't have icc and icpc. I only have ifort and gnu compilers such
>> g77,gcc
>> and g++. Since my application code works very well with ifort, can I build
>> up PETSC plus Hypre with ifort and gnu compilers? thanks.
> It might be possible (though not guaranteed if ifort conflicts with GNU
> somehow). You
> jsut provide these compilers to the configure, and use --download-openmpi.
> Matt
>> David
>> On Mon, Mar 22, 2010 at 3:29 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> If you have installation issues - send the relavent logs [in this case
>>> configure.log] to petsc-maint.
>>> Here you appear to try too many things.. But its not clear if you are
>>> installing openmpi/lam yourself - or using default from Red Hat 3.4.
>>> [note - default openmpi will be built with gnu compilers - so
>>> unuseable from ifort].
>>> Thing to do:
>>> - decide on compilers you want to use.
>>> - build PETSc and mpi with these compilers
>>> [for eg: configure CC=icc CXX=icpc FC=ifort --download-mpich=1
>>> --download-hypre=1]
>>> Note: alternative f90 compilers seable on linux are gfortran, g95
>>> Satish
>>> On Mon, 22 Mar 2010, David sheehan wrote:
>>> > Hi,
>>> > I am trying to compile the PETSC with hypre. I have Intel FORTRAN,
>>> openmpi
>>> > and lam
>>> > MPI (gcc version 3.4.6 (Red Hat 3.4.6-3)) available.
>>> > Since my application code is in FORTRAN with dynamic memory allocation
>>> in
>>> > the code,
>>> > so I have to use Intel FORTRAN(ifort) as the compiler to link PETSC
>>> with my
>>> > application
>>> > code. I can build up PETSC(petsc-3.0.0-p11) plus hypre with Lam MPI but
>>> > without ifort
>>> > successfully. However I can not use ifort to link the PETSC with my
>>> > application success-
>>> > fully. The link always shows erros about "undefined reference" to MPI
>>> parts
>>> > in my application
>>> > code such as 'mpi_send_', 'mpi_recv_', 'mpi_waitany_',
>>> 'mpi_get_count_',
>>> > and etc.
>>> > Can any one help me out? thanks in advance.
>>> > Best Regards,
>>> > David
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100322/74eaf0bf/attachment.html>
