[petsc-dev] PETSC's compilation
Mon Mar 22 15:58:42 CDT 2010
On Mon, Mar 22, 2010 at 3:54 PM, David sheehan <david.sheehanjr at gmail.com>wrote:
> I don't have icc and icpc. I only have ifort and gnu compilers such g77,gcc
> and g++. Since my application code works very well with ifort, can I build
> up PETSC plus Hypre with ifort and gnu compilers? thanks.
It might be possible (though not guaranteed if ifort conflicts with GNU
somehow). You
jsut provide these compilers to the configure, and use --download-openmpi.
   Matt
> David
> On Mon, Mar 22, 2010 at 3:29 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> If you have installation issues - send the relavent logs [in this case
>> configure.log] to petsc-maint.
>> Here you appear to try too many things.. But its not clear if you are
>> installing openmpi/lam yourself - or using default from Red Hat 3.4.
>> [note - default openmpi will be built with gnu compilers - so
>> unuseable from ifort].
>> Thing to do:
>> - decide on compilers you want to use.
>> - build PETSc and mpi with these compilers
>> [for eg: configure CC=icc CXX=icpc FC=ifort --download-mpich=1
>> --download-hypre=1]
>> Note: alternative f90 compilers seable on linux are gfortran, g95
>> Satish
>> On Mon, 22 Mar 2010, David sheehan wrote:
>> > Hi,
>> > I am trying to compile the PETSC with hypre. I have Intel FORTRAN,
>> openmpi
>> > and  lam
>> > MPI  (gcc version 3.4.6 (Red Hat 3.4.6-3)) available.
>> > Since my application code is in FORTRAN with dynamic memory allocation
>> in
>> > the code,
>> > so I have to use Intel FORTRAN(ifort) as the compiler to link PETSC with
>> my
>> > application
>> > code. I can build up PETSC(petsc-3.0.0-p11) plus hypre with Lam MPI but
>> > without ifort
>> > successfully. However I can not use ifort to link the PETSC with my
>> > application success-
>> > fully. The link always shows erros about "undefined reference" to MPI
>> parts
>> > in my application
>> > code such as 'mpi_send_', 'mpi_recv_', 'mpi_waitany_', 'mpi_get_count_',
>> > and etc.
>> > Can any one help me out? thanks in advance.
>> > Best Regards,
>> > David
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100322/967ab9f3/attachment.html>
