[petsc-dev] MatLUFactor() on MATSEQAIJ with no-inodes
Jed Brown jed at 59A2.org
Tue Mar 16 07:23:35 CDT 2010
On Tue, 16 Mar 2010 00:00:51 -0300, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> PS: I have a single warning:
> In direct memory block for handle type KEYVAL, 3 handles are still allocated
> This is because of my debug build of MPICH2, as PETSc does not frees
> all communicator keyvals it creates.
These also show up as valgrind warnings under Open MPI (presumably
MPICH2 frees them anyway in MPI_Finalize()).  The issue was discussed at
the end of a petsc-dev thread from November
  Subject: Should PetscObjectName be collective?
They could be resolved with the same approach as
  http://petsc.cs.iit.edu/petsc/petsc-dev/rev/ecbd2dcad71a
Jed
