[petsc-dev] PETSC application
Sun Mar 7 11:12:25 CST 2010
On Mar 7, 2010, at 10:57 AM, David sheehan wrote:
> >First, configure with Hypre .
> You mean, configure for the installation of PETSC with hypre? thanks.
    yes, add --download-hypre
> >Then -pc_type hypre -pc_hypre_type boomeramg
> You mean, without adding any information into code include, just
> compile and link
> the code, to get an excuteable file, e.g. "a.out", then
> a.out -pc_type hypre -pc_hypre_type boomeramg
> is it right? thanks.
    Yes,
> >I cannot understand exactly what you mean. However, if you want to
> create a PC
> > based upon a >matrix which is not the system matrix A, you can
> specify it in
> > KSPSetOperators().
> I mean Ax =b doesn't have A in explicit form, but in expression A=B
> +C1+C2+...+Cn,
> where B is main part of A in an explicity form, C1, C2,... and Cn
> are small portions
> comparing with B and they don't have an explicit form. Thus I want
> to  make a
> preconditioner from B, then apply the preconditioner to Ax=b. Please
> tell me how I
> can do by PETSC sentences for PETSC solver, thanks.
    call KSPSetOperators(ksp,A,B,......)
    Barry
> David
> On Sun, Mar 7, 2010 at 12:32 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> On Sat, Mar 6, 2010 at 11:49 PM, David sheehan <david.sheehanjr at gmail.com
> > wrote:
> Hi,
> I need your helps about PETSC as follows:
> 1) how can I call boomerAMG of HYPRE through PETSC as a solver and a
> preconditioner?
> First, configure with Hypre . Then -pc_type hypre -pc_hypre_type
> boomeramg
> 2) how can I make a precondioner  from B matrix,  but apply the
> preconditioner to Ax=b in PETSC?
> Thanks in advance.
> create a PC based upon a matrix
> which is not the system matrix A, you can specify it in
> KSPSetOperators().
>   Matt
> David
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100307/421841f9/attachment.html>
