[petsc-dev] PETSC application
Sun Mar 7 00:32:17 CST 2010
On Sat, Mar 6, 2010 at 11:49 PM, David sheehan <david.sheehanjr at gmail.com>wrote:
> Hi,
> I need your helps about PETSC as follows:
> 1) how can I call boomerAMG of HYPRE through PETSC as a solver and a
> preconditioner?
First, configure with Hypre . Then -pc_type hypre -pc_hypre_type boomeramg
> 2) how can I make a precondioner  from B matrix,  but apply the
> preconditioner to Ax=b in PETSC?
> Thanks in advance.
I cannot understand exactly what you mean. However, if you want to create a
PC based upon a matrix
which is not the system matrix A, you can specify it in KSPSetOperators().
  Matt
> David
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100307/e9c4ccba/attachment.html>
