[petsc-dev] building with mpich on OSX
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Jul 28 22:43:35 CDT 2010
On Jul 28, 2010, at 10:40 PM, Satish Balay wrote:
>> Configure Options: --configModules=PETSc.Configure --optionsModule=PETSc.compilerOptions --with-cc=gcc --download-mpich-pm=gforker --with-shared=0 --with-fc=gfortran --with-cxx=g++ --with-clanguage=cxx
> Sorry - you need '--download-mpich=1 --downlaod-pm=gforker'
  Huhh?    help.addArgument('MPI', '-download-mpich-pm=<hydra, gforker or mpd>',          nargs.Arg(None, 'hydra', 'Launcher for MPI processes'))
> Satish
> On Wed, 28 Jul 2010, Hong Zhang wrote:
>> Satish,
>> On my new MacAir (OSX 10.6.4), I got smooth configure with '--download-openmpi'
>> but error with '--download-mpich-pm=gforker':
>> C++ error! MPI_Finalize() could not be located!
>>  File "./config/configure.py", line 270, in petsc_configure
>>    framework.configure(out = sys.stdout)
>>  File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/framework.py",
>> line 946, in configure
>>    child.configure()
>>  File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/package.py",
>> line 478, in configure
>>    self.executeTest(self.configureLibrary)
>>  File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/base.py",
>> line 97, in executeTest
>>    ret = apply(test, args,kargs)
>>  File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/packages/MPI.py",
>> line 716, in configureLibrary
>>    self.executeTest(self.CxxMPICheck)
>> line 634, in CxxMPICheck
>>    raise RuntimeError('C++ error! MPI_Finalize() could not be located!')
>> The log file is attached.
>> Hong
>> On Wed, Jul 28, 2010 at 4:30 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> current workarround of for mpich on OSX is to use:
>>> Satish
>>> On Wed, 28 Jul 2010, Wesley Smith wrote:
>>>> Does anyone know if mpich is building properly on OSX.  In external
>>>> packages, I have mpich2-trunk-r6644.  When I build through petsc, I
>>>> get:
>>>> ld: duplicate symbol _HYDT_bind_info in
>>>> /Users/wesleysmith/Documents/projects/toposynth/PetSc/petsc-dev/externalpackages/mpich2-trunk-r6644/src/pm/hydra/.libs/libhydra.a(bind_hwloc.o)
>>>> and /Users/wesleysmith/Documents/projects/toposynth/PetSc/petsc-dev/externalpackages/mpich2-trunk-r6644/src/pm/hydra/.libs/libhydra.a(bind.o)
>>>> collect2: ld returned 1 exit status
>>>> make[4]: *** [hydra_nameserver] Error 1
>>>> make[3]: *** [all-recursive] Error 1
>>>> make[2]: *** [all-redirect] Error 1
>>>> make[1]: *** [all-redirect] Error 2
>>>> make: *** [all-redirect] Error 2
>>>> wes
