[petsc-dev] building with mpich on OSX
Wed Jul 28 22:40:39 CDT 2010
> Configure Options: --configModules=PETSc.Configure --optionsModule=PETSc.compilerOptions --with-cc=gcc --download-mpich-pm=gforker --with-shared=0 --with-fc=gfortran --with-cxx=g++ --with-clanguage=cxx
Sorry - you need '--download-mpich=1 --downlaod-pm=gforker'
Satish
On Wed, 28 Jul 2010, Hong Zhang wrote:
> Satish,
> On my new MacAir (OSX 10.6.4), I got smooth configure with '--download-openmpi'
> but error with '--download-mpich-pm=gforker':
> C++ error! MPI_Finalize() could not be located!
>   File "./config/configure.py", line 270, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/framework.py",
> line 946, in configure
>     child.configure()
>   File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/package.py",
> line 478, in configure
>     self.executeTest(self.configureLibrary)
>   File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/base.py",
> line 97, in executeTest
>     ret = apply(test, args,kargs)
>   File "/Users/hong/soft/petsc-dev/config/BuildSystem/config/packages/MPI.py",
> line 716, in configureLibrary
>     self.executeTest(self.CxxMPICheck)
> line 634, in CxxMPICheck
>     raise RuntimeError('C++ error! MPI_Finalize() could not be located!')
> The log file is attached.
> Hong
> On Wed, Jul 28, 2010 at 4:30 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > current workarround of for mpich on OSX is to use:
> > Satish
> > On Wed, 28 Jul 2010, Wesley Smith wrote:
> >> Does anyone know if mpich is building properly on OSX.  In external
> >> packages, I have mpich2-trunk-r6644.  When I build through petsc, I
> >> get:
> >> ld: duplicate symbol _HYDT_bind_info in
> >> /Users/wesleysmith/Documents/projects/toposynth/PetSc/petsc-dev/externalpackages/mpich2-trunk-r6644/src/pm/hydra/.libs/libhydra.a(bind_hwloc.o)
> >> and /Users/wesleysmith/Documents/projects/toposynth/PetSc/petsc-dev/externalpackages/mpich2-trunk-r6644/src/pm/hydra/.libs/libhydra.a(bind.o)
> >> collect2: ld returned 1 exit status
> >> make[4]: *** [hydra_nameserver] Error 1
> >> make[3]: *** [all-recursive] Error 1
> >> make[2]: *** [all-redirect] Error 1
> >> make[1]: *** [all-redirect] Error 2
> >> make: *** [all-redirect] Error 2
> >> wes
