[petsc-dev] CFLAGS / LDFLAGS and cxx error
Barry Smith
bsmith at mcs.anl.gov
Wed Jul 28 13:53:40 CDT 2010
On Jul 28, 2010, at 1:42 PM, Wesley Smith wrote:
> that's interesting. I had just assumed at CFLAGS would be
> concatenated onto CXXFLAGS.
Nope, they are completely distinct to handle the rare cases where the c++ compiler doesn't like all the valid flags that the C compiler accepts. Is there a way we could have made this fact obvious to users?
Barry
> I see that this isn't the case. I'll try
> again.
> wes
> On Wed, Jul 28, 2010 at 11:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Jul 28, 2010, at 1:12 PM, Wesley Smith wrote:
>>> On Wed, Jul 28, 2010 at 11:10 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> You are passing the CFLAGS="-arch i386" to C but not g++ hence g++ is using the 64 bit. You need to set CXXFLAGS also to use 32 bit.
>>> yes, but why would it not be able to find any CXX compiler when
>>> setting those flags?
>> If you look at the configure.log in detail you can see why. The g++ test works,. but then it does a test to see if the g++ and gcc compilers can be used together this fails because they are built with different arches.
>> Barry
>> sh: g++ -c -o conftest.o conftest.cc
>> Executing: g++ -c -o conftest.o conftest.cc
>> Executing: g++ -o conftest -arch i386 conftest.o
>> sh:
>> Possible ERROR while running linker: ld: warning: in conftest.o, file was built for unsupported file format which is not the architecture being linked (i386)
>> Undefined symbols:
>> "_main", referenced from:
>> start in crt1.10.6.o
>> ld: symbol(s) not found
