[petsc-dev] Cusp & Thrust test
Matthew Knepley
knepley at gmail.com
Tue Jul 27 04:39:49 CDT 2010
I fixed this, but for some reason pushing from China is not possible right
now. I also
fixed the Cusp and Thrust checks from configure, and the CUDA build stuff is
now
checked as a separate language.
Matt
On Mon, Jul 26, 2010 at 2:19 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Matt,
> With your recent NVCC change - I get the following breakage with
> my regular linux build.
> Satish
> TEST checkCUDAPreprocessor from
> config.setCompilers(/home/balay/tmp/petsc-dev/config/BuildSystem/config/setCompilers.py:531)
> TESTING: checkCUDAPreprocessor from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:531)
> Locate a functional CUDA preprocessor
> CONFIGURATION CRASH (Please send configure.log to
> petsc-maint at mcs.anl.gov)
> 'Configure' object has no attribute 'CUDACC' File
> "/home/balay/tmp/petsc-dev/config/configure.py", line 270, in
> petsc_configure
> framework.configure(out = sys.stdout)
> File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/framework.py",
> line 946, in configure
> child.configure()
> File
> "/home/balay/tmp/petsc-dev/config/BuildSystem/config/setCompilers.py", line
> 1384, in configure
> self.executeTest(self.checkCUDAPreprocessor)
> File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/base.py", line
> 97, in executeTest
> ret = apply(test, args,kargs)
> File
> 533, in checkCUDAPreprocessor
> for compiler in self.generateCUDAPreprocessorGuesses():
> File
> 528, in generateCUDAPreprocessorGuesses
> yield self.CUDACC+' -E'
> (END)
> On Mon, 26 Jul 2010, Matthew Knepley wrote:
> > On Mon, Jul 26, 2010 at 7:50 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Jul 25, 2010, at 8:26 AM, Matthew Knepley wrote:
> > > > They work with normal compilers if you drop an empty file in 'thrust'
> > > called 'host_defines.h'.
> > > > I think this should be the prefered checking mechanism since now we
> have
> > > fucked up dependencies
> > > So people who use CUDA have to drop an empty file in that strange
> system
> > > location? Doesn't sound like a good solution to the problem.
> > > Since cusp and thrust are never used with the regular compilers
> shouldn't
> > > they be tested with the compiler that actually uses them, nvcc? Thus
> you
> > > just need to add a new language CUDA to BuildSystem, which it needs
> anyways
> > > and test with that.
> > How is it that being right makes more work for me?
> > Matt
> > > Barry
> > > > again.
> > > > Matt
> > > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which
> their
> > > experiments lead.
> > > > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100727/0c894def/attachment.html>
