[petsc-dev] mpiuni and definitions of MPI_IDENT, MPI_CONGRUENT, MPI_SIMILAR
Satish Balay
balay at mcs.anl.gov
Thu Jul 8 11:38:12 CDT 2010
pushed to petsc-dev
thanks,
satish
On Thu, 8 Jul 2010, Lisandro Dalcin wrote:
> include/mpiuni/mpi.h has this:
> #define MPI_IDENT 0
> #define MPI_CONGRUENT 0
> #define MPI_SIMILAR 0
> #define MPI_UNEQUAL 3
> These definitions caused duplicate case value errors in
> Cython-generated code using C switch statement. I've already pushed a
> workaround, but perhaps you could consider defining like below:
> #define MPI_IDENT 0
> #define MPI_CONGRUENT 1
> #define MPI_SIMILAR 2
> PS: This should go to petsc-dev in order to avoid a potential ABI
> breakage in petsc-3.1
