[petsc-dev] What do people want to have working before a petsc-3.2 release?
    Sean Farley
    sean at mcs.anl.gov
    Tue Dec 21 18:00:36 CST 2010
> Just as soon as ParMetis makes their code work with 64-bit indices?
I thought Matt used the 'jed' command to fix it? ;-)
FWIW, Scotch officially supports 64-bit and seems to be much more active.
>  If you (Sean) have some time, I think that updating the Scotch interface
> would be a better use of time than trying to hack ParMetis to handle 64-bit.
Fair enough but I was just bitten by the fact that SuperLU_DIST requires
ParMetis :-(
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101221/cebb9f11/attachment.html>
