[petsc-dev] What do people want to have working before a petsc-3.2 release?
Jed Brown jed at 59A2.org
Tue Dec 21 17:56:23 CST 2010
On Wed, Dec 22, 2010 at 00:50, Sean Farley <sean at mcs.anl.gov> wrote:
> Would it be possible to get ParMetis working with 64bit indices?
Just as soon as ParMetis makes their code work with 64-bit indices?
FWIW, Scotch officially supports 64-bit and seems to be much more active.
 If you (Sean) have some time, I think that updating the Scotch interface
would be a better use of time than trying to hack ParMetis to handle 64-bit.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101222/f234b28a/attachment.html>
