[petsc-dev] SuperLU link error on BGP FEN
    Satish Balay
    balay at mcs.anl.gov
    Tue Dec 21 14:23:25 CST 2010
Sherry,
One of the patches which we still have in our superlu_dist taball is:
http://petsc.cs.iit.edu/petsc/externalpackages/SuperLU_DIST_2.4/raw-diff/ddb59df1a8a5/SRC/superlu_grid.c
could you add this to your tarball?
thanks,
Satish
On Fri, 3 Dec 2010, Barry Smith wrote:
>   Sherry,
>     Thanks, we'll upgrade to use those versions with petsc-dev.
>   Hong and Satish,
>      Could you please update petsc-dev with these newest versions of superlu[_dist]
>    Thanks
>     Barry
> On Dec 3, 2010, at 6:31 PM, Xiaoye S. Li wrote:
> > Sorry, but just got around to look at this.
> > In SuperLU_4.0, we introduced ILU preconditioner, which works better with MC64 permutation (which is written in f77).   But I forgot to include this in slu_Cnames.h, to handle the name mangling issue.
> > In SuperLU_4.1, I converted MC64 from f77 to C using f2c.   Therefore, there is no such name mangling problem.  The C version is now also used in SuperLU_DIST_2.5.
> > In summary, SuperLU_4.1 and SuperLU_DIST_2.5 upward versions should not need this name mangling for MC64.
> > Sherry
> > On Thu, Dec 2, 2010 at 1:40 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Looks like a bug in superlu. [this bug doesn't exist in superlu_dist].
> > I suspect we've always used superlu with superlu_dist on bgp - so
> > didn't see this before. [symbols from -lsuperlu_dist must have been
> > picked up by the linker (before superlu symbols) - and these symbols
> > resolved without errors]
> > The following fixes the issue.
> > login2.surveyor:SuperLU_4.0/SRC > diff -Nru slu_Cnames.h~ slu_Cnames.h
> > --- slu_Cnames.h~               2009-07-05 00:55:49.000000000 -0500
> > +++ slu_Cnames.h                2010-12-02 15:19:30.005247114 -0600
> > @@ -251,6 +251,9 @@
> >  #define izmax1_   IZMAX1
> >  #define zlacon_   ZLACON
> > +#define mc64id_         MC64ID
> > +#define mc64ad_         MC64AD
> >  /* Fortran interface */
> >  #define c_bridge_dgssv_ C_BRIDGE_DGSSV
> >  #define c_fortran_sgssv_ C_FORTRAN_SGSSV
> > @@ -350,6 +353,9 @@
> >  #define izmax1_   izmax1
> >  #define zlacon_   zlacon
> > +#define mc64id_         mc64id
> > +#define mc64ad_         mc64ad
> >  #define c_bridge_dgssv_ c_bridge_dgssv
> >  #define c_fortran_sgssv_ c_fortran_sgssv
> > I've respun the superlu download tarball with this fix..
> > Note: Looks like Superlu_4.1 tarball has this bug..
> > Satish
> > On Thu, 2 Dec 2010, Satish Balay wrote:
> > > I'll attempt a build and see how it goes..
> > > satish
> > > On Thu, 2 Dec 2010, Matthew Knepley wrote:
> > > > We always always always always need configure.log.
> > > >     Matt
> > > > On Thu, Dec 2, 2010 at 8:41 AM, John R. Cary <cary at txcorp.com> wrote:
> > > > > I am trying to link facets on a FEN of surveyor.alcf.anl.gov.  It ends
> > > > > with the error,
> > > > > /gpfs/home/projects/facets/surveyor/contrib-xlc-9.0/petsc-3.1-p4-ser/lib/libsuperlu_4.0.a(dldperm.o):
> > > > > In function `dldperm':
> > > > > /gpfs/home/cary/facetspkgs/builds/petsc-3.1-p4/ser/externalpackages/SuperLU_4.0/SRC/dldperm.c:127:
> > > > > undefined reference to `mc64id_'
> > > > > /gpfs/home/cary/facetspkgs/builds/petsc-3.1-p4/ser/externalpackages/SuperLU_4.0/SRC/dldperm.c:134:
> > > > > undefined reference to `mc64ad_'
> > > > > which indicates that the SuperLU compiled with PETSc did
> > > > > not get the fortran underscoring flag correct (which should
> > > > > be no underscore with xlf).  nm shows
> > > > > login1.surveyor$ nm
> > > > > | grep mc64
> > > > >                 U mc64ad_
> > > > >                 U mc64id_
> > > > > mc64ad.o:
> > > > > 0000000000000018 D mc64ad
> > > > > 0000000000000030 D mc64bd
> > > > > 0000000000000048 D mc64dd
> > > > > 0000000000000060 D mc64ed
> > > > > 0000000000000078 D mc64fd
> > > > > 0000000000000000 D mc64id
> > > > > 00000000000000c0 D mc64qd
> > > > > 0000000000000090 D mc64rd
> > > > > 00000000000000a8 D mc64sd
> > > > > 00000000000000d8 D mc64ud
> > > > > 00000000000000f0 D mc64wd
> > > > >                 U mc64ad_
> > > > >                 U mc64id_
> > > > > that the underscored symbol is being called, but the
> > > > > underscore-free symbol is what was defined.
> > > > > My PETSc configure line was
> > > > > #!/bin/sh
> > > > > /gpfs/home/cary/facetspkgs/builds-surveyor-xlc/facetspkgs/petsc-3.1-p4/ser/configure
> > > > >  --prefix=/gpfs/home/projects/facets/surveyor/contrib-xlc-9.0/petsc-3.1-p4-ser
> > > > >  --with-mpi=0 \
> > > > >  --with-debugging=0 \
> > > > >  --with-x=0 \
> > > > >  --with-cc='xlc_r' \
> > > > >  --with-cxx='xlC_r' \
> > > > >  --with-fc='xlf_r' \
> > > > >  --COPTFLAGS='-O2 -g' \
> > > > >  --download-superlu \
> > > > >  --with-lapack-lib=/home/projects/facets/intrepid/contrib/lapack-ser/lib/liblapack.a
> > > > >  --with-blas-lib=/home/projects/facets/intrepid/contrib/lapack-ser/lib/libblas.a
> > > > >  PETSC_DIR=/gpfs/home/cary/facetspkgs/builds-surveyor-xlc/facetspkgs/petsc-3.1-p4/ser
> > > > >  PETSC_ARCH=facets-ser \
> > > > >  --CFLAGS='-q64 -qlanglvl=redefmac' \
> > > > >  --CXXFLAGS='-q64 -qlanglvl=redefmac' \
> > > > >  --FFLAGS='-q64 -qextname=flush' \
> > > > >  --with-shared=1
> > > > > so I think that PETSc had enough info to figure out the underscoring.
> > > > > Perhaps this is a bug.
> > > > > But regardless, is there a workaround?
> > > > > Thx....John
