[petsc-dev] SuperLU link error on BGP FEN
    Hong Zhang
    hzhang at mcs.anl.gov
    Sat Dec  4 19:34:34 CST 2010
I'll do it. Hong
On Fri, Dec 3, 2010 at 9:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Sherry,
>    Thanks, we'll upgrade to use those versions with petsc-dev.
>  Hong and Satish,
>     Could you please update petsc-dev with these newest versions of superlu[_dist]
>   Thanks
>    Barry
> On Dec 3, 2010, at 6:31 PM, Xiaoye S. Li wrote:
>> Sorry, but just got around to look at this.
>> In SuperLU_4.0, we introduced ILU preconditioner, which works better with MC64 permutation (which is written in f77).   But I forgot to include this in slu_Cnames.h, to handle the name mangling issue.
>> In SuperLU_4.1, I converted MC64 from f77 to C using f2c.   Therefore, there is no such name mangling problem.  The C version is now also used in SuperLU_DIST_2.5.
>> In summary, SuperLU_4.1 and SuperLU_DIST_2.5 upward versions should not need this name mangling for MC64.
>> Sherry
>> On Thu, Dec 2, 2010 at 1:40 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> Looks like a bug in superlu. [this bug doesn't exist in superlu_dist].
>> I suspect we've always used superlu with superlu_dist on bgp - so
>> didn't see this before. [symbols from -lsuperlu_dist must have been
>> picked up by the linker (before superlu symbols) - and these symbols
>> resolved without errors]
>> The following fixes the issue.
>> login2.surveyor:SuperLU_4.0/SRC > diff -Nru slu_Cnames.h~ slu_Cnames.h
>> --- slu_Cnames.h~               2009-07-05 00:55:49.000000000 -0500
>> +++ slu_Cnames.h                2010-12-02 15:19:30.005247114 -0600
>> @@ -251,6 +251,9 @@
>>  #define izmax1_   IZMAX1
>>  #define zlacon_   ZLACON
>> +#define mc64id_         MC64ID
>> +#define mc64ad_         MC64AD
>>  /* Fortran interface */
>>  #define c_bridge_dgssv_ C_BRIDGE_DGSSV
>>  #define c_fortran_sgssv_ C_FORTRAN_SGSSV
>> @@ -350,6 +353,9 @@
>>  #define izmax1_   izmax1
>>  #define zlacon_   zlacon
>> +#define mc64id_         mc64id
>> +#define mc64ad_         mc64ad
>>  #define c_bridge_dgssv_ c_bridge_dgssv
>>  #define c_fortran_sgssv_ c_fortran_sgssv
>> I've respun the superlu download tarball with this fix..
>> Note: Looks like Superlu_4.1 tarball has this bug..
>> Satish
>> On Thu, 2 Dec 2010, Satish Balay wrote:
>> > I'll attempt a build and see how it goes..
>> > satish
>> > On Thu, 2 Dec 2010, Matthew Knepley wrote:
>> > > We always always always always need configure.log.
>> > >     Matt
>> > > On Thu, Dec 2, 2010 at 8:41 AM, John R. Cary <cary at txcorp.com> wrote:
>> > > > I am trying to link facets on a FEN of surveyor.alcf.anl.gov.  It ends
>> > > > with the error,
>> > > > /gpfs/home/projects/facets/surveyor/contrib-xlc-9.0/petsc-3.1-p4-ser/lib/libsuperlu_4.0.a(dldperm.o):
>> > > > In function `dldperm':
>> > > > /gpfs/home/cary/facetspkgs/builds/petsc-3.1-p4/ser/externalpackages/SuperLU_4.0/SRC/dldperm.c:127:
>> > > > undefined reference to `mc64id_'
>> > > > /gpfs/home/cary/facetspkgs/builds/petsc-3.1-p4/ser/externalpackages/SuperLU_4.0/SRC/dldperm.c:134:
>> > > > undefined reference to `mc64ad_'
>> > > > which indicates that the SuperLU compiled with PETSc did
>> > > > not get the fortran underscoring flag correct (which should
>> > > > be no underscore with xlf).  nm shows
>> > > > login1.surveyor$ nm
>> > > > | grep mc64
>> > > >                 U mc64ad_
>> > > >                 U mc64id_
>> > > > mc64ad.o:
>> > > > 0000000000000018 D mc64ad
>> > > > 0000000000000030 D mc64bd
>> > > > 0000000000000048 D mc64dd
>> > > > 0000000000000060 D mc64ed
>> > > > 0000000000000078 D mc64fd
>> > > > 0000000000000000 D mc64id
>> > > > 00000000000000c0 D mc64qd
>> > > > 0000000000000090 D mc64rd
>> > > > 00000000000000a8 D mc64sd
>> > > > 00000000000000d8 D mc64ud
>> > > > 00000000000000f0 D mc64wd
>> > > >                 U mc64ad_
>> > > >                 U mc64id_
>> > > > that the underscored symbol is being called, but the
>> > > > underscore-free symbol is what was defined.
>> > > > My PETSc configure line was
>> > > > #!/bin/sh
>> > > > /gpfs/home/cary/facetspkgs/builds-surveyor-xlc/facetspkgs/petsc-3.1-p4/ser/configure
>> > > >  --prefix=/gpfs/home/projects/facets/surveyor/contrib-xlc-9.0/petsc-3.1-p4-ser
>> > > >  --with-mpi=0 \
>> > > >  --with-debugging=0 \
>> > > >  --with-x=0 \
>> > > >  --with-cc='xlc_r' \
>> > > >  --with-cxx='xlC_r' \
>> > > >  --with-fc='xlf_r' \
>> > > >  --COPTFLAGS='-O2 -g' \
>> > > >  --download-superlu \
>> > > >  --with-lapack-lib=/home/projects/facets/intrepid/contrib/lapack-ser/lib/liblapack.a
>> > > >  --with-blas-lib=/home/projects/facets/intrepid/contrib/lapack-ser/lib/libblas.a
>> > > >  PETSC_DIR=/gpfs/home/cary/facetspkgs/builds-surveyor-xlc/facetspkgs/petsc-3.1-p4/ser
>> > > >  PETSC_ARCH=facets-ser \
>> > > >  --CFLAGS='-q64 -qlanglvl=redefmac' \
>> > > >  --CXXFLAGS='-q64 -qlanglvl=redefmac' \
>> > > >  --FFLAGS='-q64 -qextname=flush' \
>> > > >  --with-shared=1
>> > > > so I think that PETSc had enough info to figure out the underscoring.
>> > > > Perhaps this is a bug.
>> > > > But regardless, is there a workaround?
>> > > > Thx....John
