[petsc-dev] (PETSc-3.1-p6 & SUPERLU_dist) + ("-ksp_view" CLI option & KSPSetOptionsPrefix()/PCSetOptionsPrefix() ) = bug?
    Satish Balay
    balay at mcs.anl.gov
    Wed Dec 15 13:38:21 CST 2010
Can you try the attached patch - and see if this goes away?
patch -Np1 < superlu_dist.patch
Satish
On Wed, 15 Dec 2010, Filippo Spiga wrote:
> Dear all,
>     Sorry for the subject of this email, I had no better ideas to introduce
> the topic (-: I spent a couple of hours yesterday night trying to figure out
> about a strange behavior of PETSc-3.1-p6 using SUPERLU_dist. This problem
> arises if I combine the usage of KSPSetOptionsPrefix()/PCSetOptionsPrefix()
> and "-ksp_view" option. This is the error that I obtain:
> KSP Object:(lop_)
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=1000, initial guess is zero
>   tolerances:  relative=1e-14, absolute=1e-14, divergence=10000
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object:(lop_)
>   type: lu
>     LU: out-of-place factorization
>     tolerance for zero pivot 1e-12
>     matrix ordering: nd
>     factor fill ratio given 0, needed 0
>       Factored matrix follows:
>         Matrix Object:
>           type=seqaij, rows=242, cols=242
>           package used to perform factorization: superlu_dist
>           total: nonzeros=0, allocated nonzeros=242
>             SuperLU_DIST run parameters:
>               Process grid nprow 1 x npcol 1
>               Equilibrate matrix TRUE
>               Matrix input mode 0
>               Replace tiny pivots TRUE
>               Use iterative refinement FALSE
>               Processors in row 1 col partition 1
>               Row permutation LargeDiag
> [0|09:06:54]: unknown: MatFactorInfo_SuperLU_DIST() line 705 in
> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c: Unknown column
> permutation
> Inside the code, I have these lines:
> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp); CHKERRQ(ierr);
> ierr = KSPSetOptionsPrefix(ksp,"lop_"); CHKERRQ(ierr);
> ierr = KSPGetPC(ksp,&precond); CHKERRQ(ierr);
> ierr = PCSetOptionsPrefix(precond,"lop_"); CHKERRQ(ierr);
> ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
> ierr = KSPSolve(ksp,b,*u); CHKERRQ(ierr);
> so all the options that I pass to PETSc (using "PetscOptionsSetValue()" or
> the command line) must have the "lop_" prefix. These are my options:
> -lop_ksp_rtol 1.e-10 -lop_ksp_atol  1.e-10 -lop_ksp_monitor
> -lop_ksp_converged_reason -lop_ksp_type gmres -lop_ksp_monitor_true_residual
> -lop_pc_type lu -lop_pc_factor_mat_solver_package superlu_dist -lop_ksp_view
> If I remove "-lop_ksp_view", the error that I reported disappears (and also
> disappear the final summary
> If I remove -lop_pc_type lu -lop_pc_factor_mat_solver_package superlu_dist"
> and I use HYPRE ("-lop_pc_type hypre") and I keep the option "-lop_ksp_view"
> as valid option, the problem does not appear.
> If I remove "-lop_ksp_view" from command line but after "KSPSolve()" I add
> "KSPView()", the problem persists.
> If I suppress the prefix ("-ksp_rtol 1.e-10 -ksp_atol ... -ksp_view"), the
> PETSc-3.1-p3, PETSc-3.1-p4 and PETSc-3.1-p5 are not affected of this problem
> (other machines that I use have these versions installed, the code runs
> without problems). In the meanwhile I am recompiling PETSc-3.1-p6 on another
> machine.
> Do you have any suggestion to skip/solve this problem? (if it is a real
> problem, maybe I did something wrong...)
> Many thanks in advance,
> Cheers
> Filippo SPIGA, MSc Computer Science
> ~ homepage: http://tinyurl.com/fspiga ~
> «Nobody will drive us out of Cantor's paradise.»
>     -- David Hilbert
> Disclaimer: "Please note this message and any attachment are CONFIDENTIAL an
> may be privileged or otherwise protected from disclosure. The contents are
> not to be disclosed to anyone other than the addressee. Unauthorized
> recipients are requested to preserve this confidentiality and to advise the
> sender immediately of any error in transmission."
