[petsc-dev] (PETSc-3.1-p6 & SUPERLU_dist) + ("-ksp_view" CLI option & KSPSetOptionsPrefix()/PCSetOptionsPrefix() ) = bug?
Filippo Spiga
filippo.spiga at disco.unimib.it
Wed Dec 15 08:36:02 CST 2010
Dear all,
Sorry for the subject of this email, I had no better ideas to introduce
the topic (-: I spent a couple of hours yesterday night trying to figure out
about a strange behavior of PETSc-3.1-p6 using SUPERLU_dist. This problem
arises if I combine the usage of KSPSetOptionsPrefix()/PCSetOptionsPrefix()
and "-ksp_view" option. This is the error that I obtain:
KSP Object:(lop_)
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=1000, initial guess is zero
tolerances: relative=1e-14, absolute=1e-14, divergence=10000
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object:(lop_)
type: lu
LU: out-of-place factorization
tolerance for zero pivot 1e-12
matrix ordering: nd
factor fill ratio given 0, needed 0
Factored matrix follows:
Matrix Object:
type=seqaij, rows=242, cols=242
package used to perform factorization: superlu_dist
total: nonzeros=0, allocated nonzeros=242
SuperLU_DIST run parameters:
Process grid nprow 1 x npcol 1
Equilibrate matrix TRUE
Matrix input mode 0
Replace tiny pivots TRUE
Use iterative refinement FALSE
Processors in row 1 col partition 1
Row permutation LargeDiag
[0|09:06:54]: unknown: MatFactorInfo_SuperLU_DIST() line 705 in
src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c: Unknown column
permutation
Inside the code, I have these lines:
ierr = KSPCreate(PETSC_COMM_WORLD,&ksp); CHKERRQ(ierr);
ierr = KSPSetOptionsPrefix(ksp,"lop_"); CHKERRQ(ierr);
ierr = KSPGetPC(ksp,&precond); CHKERRQ(ierr);
ierr = PCSetOptionsPrefix(precond,"lop_"); CHKERRQ(ierr);
ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
ierr = KSPSolve(ksp,b,*u); CHKERRQ(ierr);
so all the options that I pass to PETSc (using "PetscOptionsSetValue()" or
the command line) must have the "lop_" prefix. These are my options:
-lop_ksp_rtol 1.e-10 -lop_ksp_atol 1.e-10 -lop_ksp_monitor
-lop_ksp_converged_reason -lop_ksp_type gmres -lop_ksp_monitor_true_residual
-lop_pc_type lu -lop_pc_factor_mat_solver_package superlu_dist -lop_ksp_view
If I remove "-lop_ksp_view", the error that I reported disappears (and also
disappear the final summary
If I remove -lop_pc_type lu -lop_pc_factor_mat_solver_package superlu_dist"
and I use HYPRE ("-lop_pc_type hypre") and I keep the option "-lop_ksp_view"
as valid option, the problem does not appear.
If I remove "-lop_ksp_view" from command line but after "KSPSolve()" I add
"KSPView()", the problem persists.
If I suppress the prefix ("-ksp_rtol 1.e-10 -ksp_atol ... -ksp_view"), the
PETSc-3.1-p3, PETSc-3.1-p4 and PETSc-3.1-p5 are not affected of this problem
(other machines that I use have these versions installed, the code runs
without problems). In the meanwhile I am recompiling PETSc-3.1-p6 on another
machine.
Do you have any suggestion to skip/solve this problem? (if it is a real
problem, maybe I did something wrong...)
Many thanks in advance,
Cheers
Filippo SPIGA, MSc Computer Science
~ homepage: http://tinyurl.com/fspiga ~
«Nobody will drive us out of Cantor's paradise.»
-- David Hilbert
Disclaimer: "Please note this message and any attachment are CONFIDENTIAL an
may be privileged or otherwise protected from disclosure. The contents are
not to be disclosed to anyone other than the addressee. Unauthorized
recipients are requested to preserve this confidentiality and to advise the
sender immediately of any error in transmission."
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101215/e096cdf6/attachment.html>
