[petsc-dev] Partial build a lib
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Dec  8 16:56:33 CST 2010
  Look for Cmake in http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html and report all problems to Jed at this email. In particular the line Run make in the build directory  in the directions looks like gibberish to me. What build directory? What the heck is a build directory :-)
   I used make -j2 -C $PETSC_ARCH
successfully, but Jed needs to fix the documentation here.
  Barry
On Dec 8, 2010, at 4:41 PM, Ryan Yan wrote:
> Dear All,
> I am wondering is it possible to only partially update the PETSc build.
> For instance, if I modified some function in src/mat/impls/aij/mpi/mpiaij.c, what should
> I do to enforce this change, instead of building everything again.
> ( I guess it's the "make lib" under the src/mat/impls/aij/mpi, right? I think I asked the same question before...  )
> Any pointer to the target and rules will be appreciated.
> Thanks,
> Yan
