[petsc-dev] Fortran 2003 enum
    Blaise Bourdin
    bourdin at lsu.edu
    Wed Dec  8 16:36:02 CST 2010
>> On Tue, Dec 7, 2010 at 20:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> In fact many of the Fortran manual bindings come from string issues.
>> Why has this not been automated?  I don't know the bfort source, but is it somehow fundamentally hard?
>  It is not fundamentally hard, just a few different cases for different compilers and a bit of a pain in the butt to automate. We've managed ok without automating. If you tried to do it in bfort I think you (like Matt) would bitch and scream and swear that bfort should be rewritten in python :-)
>   Anyways the issue with what Blaise wants is arrays of strings, we have no experience with arrays of strings, someone would just need to sit down and see how all Fortran compilers handle them and then write stubs to deal with them. Never been a priority for use because didn't know that Blaise wanted this.  Could be done.
Wow, I didn't know I had such powers ;)
I would have done it myself if it didn't involve passing strings. I don't understand C strings in general and I understand the magic involved in the fortran bindings involving strings even less.
>   But if 2003 provides a standard way of doing this then we could just use that and save the manual work.
I have done a little bit of reading and asked for help on the intel fortran compiler forum.
(see http://software.intel.com/en-us/forums/showthread.php?t=79287&p=1#136682 )
I am attaching an example showing how to pass scalar by value or address, arrays of scalar, and arrays of strings. This last one was tricky and even though it compiles and runs fine using the intel and gnu compilers, I am not completely sure that it is legit. I am waiting on feedback from the intel people.
You have access to more machines than I do, so perhaps you can test this example on several platforms? If it works, would you consider using this mechanism in cases where standard bindings are tricky?
Blaise
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101208/7851ce0c/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101208/7851ce0c/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101208/7851ce0c/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101208/7851ce0c/attachment-0003.obj>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
