[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
    Jed Brown
    jed at 59A2.org
    Tue Dec  7 15:27:23 CST 2010
On Tue, Dec 7, 2010 at 22:00, Barry Smith <bsmith at mcs.anl.gov> wrote:
> PetscLayout is like the DMSliced, there is simply no interconnectivity
> information because it is not needed or not available. It tells enough
> information to serve as a factory for Flat Euclidean space in the same way
> that DMDA serves as a factory for slightly more complicated layout.
Okay, I agree now.  And Mat would then naturally have a "row" and "column"
DM (making MatGetVecs for non-standard DMs trivial).  It's not clear to me
what this semantic information allows, but a linear transformation, in an
abstract sense, is a map between spaces, so it's mathematically sound to
have the linear transformation (Mat) know about the spaces.)
There is that little detail of PetscLayout currently being an "open" object.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101207/0a830338/attachment.html>
