[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
Jed Brown
jed at 59A2.org
Tue Dec 7 13:59:09 CST 2010
On Tue, Dec 7, 2010 at 20:53, Barry Smith <bsmith at mcs.anl.gov> wrote:
> BTW: I consider the DMDA Vec just a very special case that gets way to much
> attention and can sometimes distort the overall design of PETSc in issues
> that are not important in that non-special case.
Along these lines, I'm curious about using an API like VecGhost for the DA.
That is, what if there was a level where a Vec could know about a local
form. When you get the local form, one implementation would return the
contiguous local form (no copy) and another implementation would return a
separate vector. Then you could
VecUpdateVector(Xglobal,Xlocal,imode,scattermode) or so (need an unambiguous
name). Then DMComposite could operate without forcing separate local and
global vectors.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101207/731c89bb/attachment.html>
