[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
Tue Dec 7 13:53:08 CST 2010
On Dec 7, 2010, at 1:50 PM, Jed Brown wrote:
> On Tue, Dec 7, 2010 at 20:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Why can you not use VecAXPY() on the local Vecs?
> You're absolutely right.  I must have been thinking of error control when I decided this was a problem.  You need some sort of norms and don't want to double-count the ghost entries.
   Yes, norms are an issue in the case of DMDA. When using ghosted local vectors norms are fine.
   BTW: I consider the DMDA Vec just a very special case that gets way to much attention and can sometimes distort the overall design of PETSc in issues that are not important in that non-special case.
   Barry
> Jed
